Results 1 to 6 of 6
Thread: BARO_B and MAP not going over 100KPA
    Senior Member Behold's Avatar
    Apr 2010
    Default BARO_B and MAP not going over 100KPA
    I have installed a 2 Bar sensor and have it set to what I think is about right on the scaler but both the BARO_B and MAP pid once its over 100kpa just sit at 100KPA surely if i was to put in something like 205 it will read well over 100kpa proving the PID works??
    I saw 4 weeks ago TRANSZ_AM had a similar issue. Im on a COS5 using a LS1B Controller. thoughts??? Unfortunatly until my SC is fitted i have noway to move the voltage to over the 2.7 its reading at the moment.
    Lifetime Member Mr. P.'s Avatar
    May 2007
    Yeah I would think that if you increase the scaler value from 190 to 205 then the PCM-calculated/reported MAP PID should rise as a result.
    The car is not forced-induction yet, so are you just wanting to test or calibrate the MAP sensor??? If you want to calibrate the sensor, then just look-up the current weather info for your area and get the barometric pressure, convert to Kpa, and then fudge your scaler/offset values until the key-off MAP sensor reading matches the current weather barometer reading. If you want to over-do the process, you could find a calibrated air source (air compressor?) and pressurize the map sensor with 14.7psi air pressure and your PCM's MAP PID should report a value of approximately 200Kpa (the actual value will be [your current atmospheric Kpa] + 100Kpa) but to do this you would need a very well calibrated low-pressure air source, my crappy Craftsman air compressor cannot regulate air pressure that low and if I tried to do something like that I would overpressurize and possibly damage the sensor!
    Mr. P.
    2003 Silverado SS, with Novi-1500 "CAI mod"
    EFILive V 7.5 COS-3 (OLSD, for now!)
    Apr 2010
    Im just proving it works so that once fitted I can start logging VE data. But at the moment its not going over 100 with the scaller modified. Tempted to set it to 288 to see what happens but Im not holding out hope....
    May 2007
    What OS are you using?
    Apr 2010
    Quote Originally Posted by Mr. P. View Post
    01290005 Its a COS5.
    Apr 2010
    Any further ideas??? Im just awaiting my pully Puller and the SC will be fitted... I need to know that I can start tuning and using the 2 bar sensor. Is there any way to prove the OS is or isn't the issue????
  1. preconfig map
    By ls1miata in forum Gen III V8 Specific
    Last Post: May 15th, 2009, 12:29 PM
  2. MAP/TP Correlation
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: February 10th, 2009, 06:13 PM
  3. Changing from a 2bar map to a 3bar map?
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 23rd, 2006, 04:31 PM
  4. Link to MAP
    By TAQuickness in forum General
    Last Post: September 8th, 2006, 05:07 AM
  5. KR Map
    By 98WhiteDevil in forum General
    Last Post: August 12th, 2006, 01:15 PM
