Results 1 to 2 of 2
Thread: Aldl connection to V4
    Jul 2011
    Default Aldl connection to V4
    Hey guys.
    I bought a Aldl cable and tested it out. I am having problems reading live data.
    max232 interface lights up green also the chatter lights up green on macros mode.
    I tried changing the ID on the data stream definition when a type in F1 the engine light comes on and the high fan speed comes on but no data this is with car running.
    Here is what i get
    04:39.014: Check vehicle interface...
    04:39.023: Waiting for Aldl bus silence of at least 16ms...
    04:39.061: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    04:39.077: Max232 interface detected OK
    04:39.078: Scanning for heartbeat and chatter frames...
    04:39.078: Waiting for Aldl bus silence of at least 16ms...
    04:39.449: Com timeout: Expecting frame header byte
    04:39.461: Heartbeat frame:
    04:39.461: 04:39.205: $A8,$55,$03
    04:39.461: Heartbeat frame is followed by 16ms of silence
    04:39.461: Advisable value for T6 is 8ms
    04:39.461: Chatter frame(s):
    04:39.461: 04:39.221: $20,$55,$8B
    04:39.461: 04:39.237: $21,$58,$A8,$35,$46,$64
    04:39.461: 04:39.237: $D8,$55,$D3
    04:39.461: 04:39.253: $90,$55,$1B
    04:39.461: 04:39.269: $91,$58,$18,$00,$00,$FF
    04:39.461: 04:39.285: $A0,$55,$0B
    04:39.462: 04:39.285: $A1,$57,$08,$00,$00
    04:39.462: 04:39.301: $11,$5C,$FF,$40,$48,$00,$00,$00,$00,$0C
    04:39.462: 04:39.317: $40,$58,$57,$6A,$00,$A7
    04:39.462: 04:39.333: $41,$63,$00,$00,$00,$81,$62,$00,$00,$00,$F8,$31,$0 0,$00,$10,$5F,$E1
    04:39.462: 04:39.349: $08,$55,$A3
    04:50.847: Start macro: Engine data: DATA
    04:50.859: Synchronising ALDL communications...
    04:50.859: Waiting for heartbeat: $08,$55,$A3
    04:50.859: Waiting for Aldl bus silence of at least 16ms...
    04:51.110: Send: $08,$57,$01,$00,$A0
    04:51.242: Com timeout: Expecting frame header byte
    04:51.258: Send: $08,$57,$01,$00,$A0
    04:51.386: Com timeout: Expecting frame header byte
    04:51.393: Send: $08,$57,$01,$00,$A0
    04:51.515: Com timeout: Expecting frame header byte
    04:51.521: Resuming normal ALDL communications...
    04:51.550: Stop macro: Engine data: DATA
    Jul 2011
    Hey guys got it working.
    But is it normal for the high fan speed to come on when i am checking live data?
    Is there are way to turn the fan off?
    I am using efi live v4 demo version
  1. ALDL integrated into v7.5 / v8
    By limited cv8r in forum General
    Last Post: June 14th, 2011, 07:13 PM
  2. V4 ALDL Dashboard
    By willy jordison in forum EFILive V4
    Last Post: March 25th, 2011, 12:51 PM
  3. ALDL Integration
    Last Post: June 13th, 2010, 07:50 AM
  4. ALDL help/guru's
    By limited cv8r in forum EFILive V4
    Last Post: August 15th, 2007, 01:29 PM
  5. ALDL Scan Option
    By CGTMS in forum FlashScan V2
    Last Post: February 8th, 2007, 01:41 PM
