Hey guys.
I bought a Aldl cable and tested it out. I am having problems reading live data.
max232 interface lights up green also the chatter lights up green on macros mode.
I tried changing the ID on the data stream definition when a type in F1 the engine light comes on and the high fan speed comes on but no data this is with car running.
Here is what i get
04:39.014: Check vehicle interface...
04:39.023: Waiting for Aldl bus silence of at least 16ms...
04:39.061: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
04:39.077: Max232 interface detected OK
04:39.078: Scanning for heartbeat and chatter frames...
04:39.078: Waiting for Aldl bus silence of at least 16ms...
04:39.449: Com timeout: Expecting frame header byte
04:39.461: Heartbeat frame:
04:39.461: 04:39.205: $A8,$55,$03
04:39.461: Heartbeat frame is followed by 16ms of silence
04:39.461: Advisable value for T6 is 8ms
04:39.461: Chatter frame(s):
04:39.461: 04:39.221: $20,$55,$8B
04:39.461: 04:39.237: $21,$58,$A8,$35,$46,$64
04:39.461: 04:39.237: $D8,$55,$D3
04:39.461: 04:39.253: $90,$55,$1B
04:39.461: 04:39.269: $91,$58,$18,$00,$00,$FF
04:39.461: 04:39.285: $A0,$55,$0B
04:39.462: 04:39.285: $A1,$57,$08,$00,$00
04:39.462: 04:39.301: $11,$5C,$FF,$40,$48,$00,$00,$00,$00,$0C
04:39.462: 04:39.317: $40,$58,$57,$6A,$00,$A7
04:39.462: 04:39.333: $41,$63,$00,$00,$00,$81,$62,$00,$00,$00,$F8,$31,$0 0,$00,$10,$5F,$E1
04:39.462: 04:39.349: $08,$55,$A3
04:50.847: Start macro: Engine data: DATA
04:50.859: Synchronising ALDL communications...
04:50.859: Waiting for heartbeat: $08,$55,$A3
04:50.859: Waiting for Aldl bus silence of at least 16ms...
04:51.110: Send: $08,$57,$01,$00,$A0
04:51.242: Com timeout: Expecting frame header byte
04:51.258: Send: $08,$57,$01,$00,$A0
04:51.386: Com timeout: Expecting frame header byte
04:51.393: Send: $08,$57,$01,$00,$A0
04:51.515: Com timeout: Expecting frame header byte
04:51.521: Resuming normal ALDL communications...
04:51.550: Stop macro: Engine data: DATA
