Results 1 to 6 of 6
Thread: 02 switch points
    Lifetime Member smslyguy's Avatar
    Oct 2008
    Default 02 switch points
    Does the factory o2 infact switch from lean to rich? Meaning it should show up on your wideband as switching from lean to rich. NOt switching at stoich to rich. correct? When i am at freeway speeds my wideband shows 14.4 and lower. is this normal? I have to assume that it would be cause at cruising speeds i am achieving 29 m.p.g. Maybe it's just a wideband error?? It is my second one. Any comments??
    2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
    Now own a 2015 1LE camaro
    Apr 2011
    from what i understand about o2 operation, it switches from lean to rich but averages around 450 which is stoich.
    Mar 2005
    It actually goes from lean to Stoich lean to stoich...14.4 is about right...don't sweat it mate....you CAN change the switch point to say 400ms and you'll see a small drop in AFR to about 14.5/6 but only in the LS1 ECU's.
    You achieve far better results with economy by setting the timing correctly just a wee HINT. Changing AFR from 14.4 to 14.6 achieves very little compared to getting the timing right.
    http://forum.efilive.com/showthread....ng-i-want-more
    see this post where I comment on wanting more timing in a cammed car but am limited to 40deg by the ECU > HINT EFILIVE guys can this be changed < in the post I've placed a log screen shot of vacuum vs timing using BIDI control...its self explanatory...so more timing to a point gives more vacuum and hence better fuel economy at light load points
    "Just a tune > yeah right !!!! "
    Oct 2008
    Being we are on the topic of fuel economy, you wouldn't happen to have the patch for lean cruise? Or is the patch floating around here good for any pcm? Also where do you put the lean cruise patch? I thought i read that it goes in the cax file, but where is that? Is that in the user configeration?
    May 2008
    The custom OS you can change B3647 instead of lean cruise.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    +1 use B3647.
    Otherwise, the CAX subforum has the LC patches.
  1. Going from DSP2 switch to DSP5 switch
    By Dmax15 in forum Duramax LB7
    Last Post: February 23rd, 2010, 03:25 PM
  2. shift points
    By rock04max in forum General
    Last Post: December 1st, 2008, 01:09 PM
  3. VE Table Tuning and the O2 Switch points.
    By TFZ_Z06 in forum Gen III V8 Specific
    Last Post: August 17th, 2008, 06:28 AM
  4. 02 Switching points
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: November 6th, 2007, 05:13 AM
  5. Closed Loop Lean Cruise Idea (O2 Switch Points)
    By BlackGMC in forum Gen III V8 Specific
    Last Post: October 25th, 2007, 08:18 AM
