Originally Posted by
Mr. P.
I would agree that is pretty hot (112* c = 234* f) but no hotter than my best friend's 2010 Z06, it's ECT is 230-ish. Is the engine always that hot, or just at low speeds? If the ECT is fine at freeway speeds then the radiator is not the issue, it is lack of fan airflow and/or coolant flow when parked. Another possible, the factory water pumps on LS motors do not circulate much water at idle, we run into this on trucks a lot of the time and increasing idle to 1000-RPM for a couple moments has in a few cases brought the temps down 10-15 degrees, but on our projects "hot" for us was 210 not 234!
Mr. P.
