I have had my LC1 laying around for 2 years. PLX finally gave up so now I need to setup LC-1.
I have the cable from TAQUICKNESS figured out. Just wanted to make sure I am hooking up brown wire properly. From what I can see, the brown wire goes directly to a power supply and not to the V2. (Yellow wire will not be used)
Just wondering if there is a better system out there than the LC-1 that works with TAQuickness cables? I saw the list of supported wb controllers. I just want one that is EASY to setup, doesn't require the soldering needed with the LC-1.
