I couldn't find this anywhere so here is one possible cause of Error $0185
Having the checkbox "Load previously used PID's" checked and then updating will cause it.
Drove me nuts, till I unselected it, and the error went away.
Wolfie
LS1B 2007 Express 6.0 /w 470,000+ miles (parked as of 01April2011)
This could happen if the firmware tat you updated from was extremely old. The folder naming structure was changed (well over a year ago), so if the old PID list was in a now incorrect location/structure you will get that error I expect. The resolution of course is to leave that check box enabled and select the PID list again through the device keypad.
Andrew
EFILive Crew
