OK ... as a disclaimer I am just starting to work with Gen IVs ... Swingtan is our resident expert.
You had asked that I explain any changes ... here goes ... the tune had not been properly setup for VVE tuning.
The attached tune below should be in OL with STFT, LTFT, DFCO, and MAF disabled - ready for the VVE tuning process.
- B1503 & B1504 had not been disabled
- B0156 was set to 0.4 - it should have been set to 4.0
- the MAF & MAF associated MILs were not setup per the VVE tutorial
- B8101 had an error in zone 12 - too few cells - caused by your B8021 (MAP Zone Boundary) settings
Do not forget to reset the LTFT - even if these are disabled they will continue to be applied unless reset.
Regards,
Taz
