Results 1 to 2 of 2
Thread: Error $0185, one fix?
    Senior Member Wolfie's Avatar
    Dec 2007
    Default Error $0185, one fix?
    I couldn't find this anywhere so here is one possible cause of Error $0185
    Having the checkbox "Load previously used PID's" checked and then updating will cause it.
    Drove me nuts, till I unselected it, and the error went away.
    Wolfie
    LS1B 2007 Express 6.0 /w 470,000+ miles (parked as of 01April2011)
    Oct 2004
    This could happen if the firmware tat you updated from was extremely old. The folder naming structure was changed (well over a year ago), so if the old PID list was in a now incorrect location/structure you will get that error I expect. The resolution of course is to leave that check box enabled and select the PID list again through the device keypad.
    Andrew
    EFILive Crew
  1. $0183 error, how to fix?
    By jheyob in forum FlashScan V2
    Last Post: May 17th, 2010, 12:24 PM
  2. Error: $0185
    By gpr in forum Gen III V8 Specific
    Last Post: September 18th, 2009, 09:39 AM
  3. error $0183 and $0185
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: May 24th, 2009, 04:39 PM
  4. $0185 error
    By hymey in forum FlashScan V2 BB Logging
    Last Post: March 24th, 2008, 12:52 AM
  5. Error $0185 when copying files
    Last Post: December 31st, 2007, 06:19 AM
