Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 6.7L rail pressure sensor in a 5.9?
    Dec 2007
    Default 6.7L rail pressure sensor in a 5.9?
    I have been told that the rail pressure sensor from a 6.7L has the same thread pattern & electrical connection as the ones in the 5.9?
    Anyone able to validate this? Also wondering if anyone has upgraded & respanned their 5.9 with this mod?
    my truck goes through a sensor at least every 6 months (its gotta be the diprocol rail pressure gauge.....) at $450/sensor from the dealer im getting a little fed up of this. It looks like I have another one going now & I was thinking of trying this mod....
    *yes, i have seen replacement sensors online for under $100, but of course they seem to go at the worst time when im in the middle of nowhere*
    06 Laramie 3500 QC SB 4x4 - Full billet Auto by DTT, HE351/S475 twins, EFI live, lots of custom goodies....
    07 6.2L Yukon Denali - CAI, CAT delete, self tuned with EFI Live
    03 Trailblazer 4.2L I6 - CAI, custom exhaust, EFI live
    2010 Laramie 3500 CC LB 4x4 - H&S, DPF delete, waiting for EFI Live.....
    Jul 2011
    I understand that the connector is slightly different, but can be easily modified to work.. A 6.7 rail pressure gauge would be needed, but the ISSPRO one works on both connectors so no modification would be necessary.
    IIRC you would run approx 13% higher rail pressure unless you re-map the sensor voltage.
    Lifetime Member FUBAR's Avatar
    Feb 2011
    Excuse my ignorance.. But is the 6.7 sensor more robust or ??
    06 LBZ, EFILive
    Nov 2010
    Quote Originally Posted by FUBAR View Post
    There is a thought that the 6.7 sensor is a 30K sensor from the factory...
    ~Les
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Lifetime Member DoghouseDiesel's Avatar
    Dec 2009
    Just be careful if you use it.
    Just because the sensor can read higher, doesn't mean your fuel system can handle the higher pressures.....especially if you have the old style injectors in the early '06's.
    Start pushing 28K psi and you're gonna do damage.
    If you have the newer style stainless steel injectors and are using the larger 6.7 connector tubes, rail and lines, it's a little more forgiving, but just changing the sensor so you can see the higher pressures is like putting a depth finder on a boat and running in shallow water....by the time you see something, the damage is already done.
    1207 HP / 1612 TQ
    Jul 2011
    From some old notes I have the 5.9 sensor has a range of 0-26107 psi and the 6.7 has a range of 0-30000 psi, in the same 0-5v reading.
    There are several people running a 6.7 sensor just for the 13% rail pressure increase across the board.
    Nov 2010
    Although I am not a fan of running pressures of over stock, it would be nice to see what my actual pressures are on a spike at the end of a WOT run....seeing 27.5K on the gauge...I know it's getting higher.
    ~Les
    I am here: http://maps.google.com/maps?ll=37.996567,-122.070181
    Les Szmidt
    2007 5.9 Dodge Ram
    Dec 2009
    Quote Originally Posted by 2007 5.9 View Post
    ~Les
    Nor am I.
    Lot of risk for minimal gain.
    Most of the damage I see come in is from a combination of 3 things.....
    1 - Mod or Dual CP3's
    2 - Relief valve removed or modified
    3 - Pressure box; specifically MP8's.
    Those 3 right there are the common denominators that I see with injector and piston damage.
    Do I run a relief valve? No.
    Do I run dual CP3's? Yes.
    Do I run RP higher than 24K psi? No.
    1207 HP / 1612 TQ
    Jul 2011
    Has anyone noticed how much lower pressure the 6.7's run while cruising? They do go much higher under load, but are considerably lower at low load... maybe Dodge/Cummins realized the gain wasn't worth it and dropped the average pressure to get longer life?
    Dec 2009
    That may also be due to the emissions requirements, which is more than likely the bigger issue.
    1207 HP / 1612 TQ
  1. low fuel rail pressure
    By joev4628 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 23rd, 2011, 03:50 PM
  2. fuel rail pressure
    By drdarthinvader in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2009, 07:17 PM
  3. walbro 255 pressure at the rail..........?
    By mr.prick in forum Gen III V8 Specific
    Last Post: August 14th, 2007, 06:43 AM
  4. Fuel Rail Pressure
    By Dave Lewis in forum Duramax LB7
    Last Post: July 30th, 2006, 02:54 PM
