Results 1 to 4 of 4
Thread: How does this Injector Flow Base table work?
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Default How does this Injector Flow Base table work?
    Can someone explain the basics on this type of table. It's not like any other years 2007 & up that I have seen in trucks.
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
    Aug 2010
    Hello 67SS509,
    Take a look at the thread attached below ...
    http://forum.efilive.com/showthread....-Delta-MAP-Kpa...
    From about post #18 onward it should help understanding the relationship between Delta Map kPa, MANVAC, BARO, and injector flow rate.
    With Gen III controllers (LS1-B) the OEM parameters generally had small variations in injector flow (B4001) - year to year - platform to platform. That trend does not seem to be true for the Gen IV controllers (E38 / E67). Visually, Gen IV B4001 parameters may:
    • slope in an upward curve from the lower left to the upper right
    • look as they do in the tune you posted - a backward "Z" type pattern
    • or as in some GMPP E-Rod tunes - an "N" canted forward at 45 degrees
    In a NA (naturally aspirated) application as long as the B4001 Delta MAP kPa values are accurate in the 400 to 480 range of cells - with respect to the injectors being used in the specific application - the tune should work fine.
    Regards,
    Taz
    Dec 2005
    Thanks, this was a big help but I'm still a little short to fully understanding what I read. On this tune I posted what would the injector size be? I'm guessing 38lbs/hr based on what I just read. I have no idea what GM says for 2008 Chevy truck with a 5.3 but with "Flex Fuel" it probably could be that big.
    Aug 2010
    Working in Delta MAP kPa does not come naturally to me either - I always have to double check my thinking. To convert from lbs/hr to g/s multiply by 0.1259. To convert from g/s to lb/hr divide by 0.1259. These conversions will yield an approximate result.
    Your 38 lb/hr example above - loosely equates to 4.7842 g/s.
    In the tune you posted:
    • the 400 Delta MAP kPa value was 4.5861 - or loosely 36 lb/hr
    • the 480 Delta MAP kPa value was 4.9520 - or loosely 39 lb/hr
    When comparing injector flow rates, always remember to compare them at the same fuel pressure - the Gen III / IV operate at 58 PSI of fuel pressure - or "4 bar" (4 times standard barometric pressure).
    Regards,
    Taz
  1. injector flow rate table
    By hpcubed in forum General (Petrol, Gas, Ethanol)
    Last Post: December 10th, 2012, 07:29 AM
  2. injector flow rate table
    By stripes in forum Gen III V8 Specific
    Last Post: May 18th, 2008, 05:44 AM
  3. Injector flow base
    By johnv in forum Gen IV V8 Specific
    Last Post: September 16th, 2007, 11:54 AM
  4. LS7 injector flow rate (base) table?
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: April 15th, 2007, 07:23 AM
  5. the injector flow rate table..
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: August 10th, 2005, 02:17 PM
