Results 1 to 4 of 4
Thread: cant do a comparison between tune?
    Junior Member browneflatwork's Avatar
    Nov 2009
    Default cant do a comparison between tune?
    i have a modifed tune with OS "A" and my stock file has operating system "B" i pull up stock file convert to imperial i try to pull up load and comparison tune but its not letting me open the modifed tune with differnt OS, says will not show comparison bec of different OS? sry if this is hard to understand long story short im trying to convert modifed tune into script to run over my new stock file OS
    EFI....SC IV,fass 150,sleeves, MBRP 4in TB,afe intake, shimmed rail, blocked egr,auto meter c2 gauges, home built trac bars,
    Jan 2006
    you cant compare different operating systems
    Nov 2009
    How do I get modified tune into script? I've looked at tutorials and I think I'm missing something
    Jan 2006
    You have to compare it to a stock tune with the same OS. Be careful when running a script on a different OS since it may have tables added or removed.
  1. Comparison???
    By bc3tech in forum FlashScan V2
    Last Post: November 29th, 2007, 07:45 AM
  2. Convince me to change to a 2bar tune...709rwhp through an EFI maf tune.
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 16th, 2006, 12:04 PM
  3. calibration comparison feature
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: April 16th, 2005, 02:09 PM
