Results 1 to 8 of 8
Thread: No timing tables in Calibration
    Junior Member chrleb2's Avatar
    Jan 2008
    Default No timing tables in Calibration
    I pulled a stock tune out of a truck and was going to tune it. When I went into the main timing, there was not any main base tables. I haven't looked over the rest of the tune though. I'm attaching a copy of it so you guys can check it out.
    Thanx,
    Erick
    03 5.9L Cummins, Sitting in pieces
    98 5.9L.... Gone to Sweden
    08 D-max, Ol' Faithful....
    Brown's Diesel
    Lifetime Member 06redram's Avatar
    Jan 2011
    I looked at you file, you are missing alot of tables. I am pretty sure EFI tech will chime in
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    Truck may have had a box tuner on it at one time and some tables were not returned to the truck. I have nothing to back this up. Just a possibility maybe?!?!
    Spray & Pray
    Dec 2007
    have you tried finding the appropriate "stock" tune from the tune repository and reflashing with that? should be able to build from that base
    06 Laramie 3500 QC SB 4x4 - Full billet Auto by DTT, HE351/S475 twins, EFI live, lots of custom goodies....
    07 6.2L Yukon Denali - CAI, CAT delete, self tuned with EFI Live
    03 Trailblazer 4.2L I6 - CAI, custom exhaust, EFI live
    2010 Laramie 3500 CC LB 4x4 - H&S, DPF delete, waiting for EFI Live.....
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Efi will correct this for you i'm sure bud. Thanks for the post, this is the only way problems can be acknowledged and corrected.. You can get a stock file for this truck from compd or tunefiledepot... just make sure it is a 48RE. just make sure you put the correct vin in whatever stock file you pull with the scan tool while the truck is connected.
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Jan 2008
    I had another Calibration that worked with the truck. I ended up using it and swapped VINs in the program. Just wanted to bring it up so that EFI could see this calibration. Probably and odd one from Dodge.
    Brown's Diesel
    Jul 2011
    I had the same issue, havent had time to post it up. I ended up loading a programmer on it then taking it back out. It updated the OS and the tables were there with the updated OS. I have attached the original OS. The AM is the original stock tune, the AS is the updated.
    35325553AM.ctd35325553AS.ctd
    on edit just looked at OP's file, its the same one
    Hey guys, yes that OS is a really early one, I know there is some tables missing in it compared to all others but for the most part it should be pretty complete.
    I can take another look, but, the easy (and probably better answer) is to update the ECM to a later OS.
  1. Idle timing tables
    By 1000HP in forum Duramax LLY
    Last Post: February 28th, 2011, 06:42 PM
  2. Confused...Timing tables changed
    By MMLMM in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 7th, 2009, 02:43 PM
  3. DSP5; Alternate Calibration tables are wrong
    By Intel in forum General (Diesel)
    Last Post: December 10th, 2007, 01:24 PM
  4. Optimized VE and Timing tables
    By neil in forum Gen III V8 Specific
    Last Post: October 14th, 2007, 12:35 PM
  5. Can the timing tables 'x' axis be changed
    By Jason S. in forum General (Petrol, Gas, Ethanol)
    Last Post: May 1st, 2007, 07:54 PM
