Can you post a log file...?
What are you using to tune the ECM...?
svep6.efisvep2-4.efi
cant get the logs in here can i email u them?
i am using efilive.
thanks christoffer
The logs attached just fine, I can open them no problem.
That ECM can be flashed ok, you're not having any problems flashing it...?
Hmmm...the ECM is throwing P0606.
no problem flashing it.
Hi Christoffer,
From the log files, it looks to me like catalytic over-temperature protection is enabling.
Can you post your file...?
Under the Engine Calibration folder there should be a subfolder named Cat Converter.
i tried to post it but it diddnt work.if you give me your email i can send it?
