Results 1 to 3 of 3
Thread: ? on flashing tune
    Jan 2011
    Default ? on flashing tune
    I have A 2010 silverado with A 6.0 that I puchased A tune from someone . I flashed the transmission and see the differance . When I flash the engine pcm should I be doing A full flash with crank relearn or just the calibration flash? I just dont see any change in performance when i did the calibration flash .
    Aug 2010
    Hello Dave,
    Whether to flash only the calibration or to flash the calibration and OS (full flash) depends on the changes to the tune. If only parameters in the tune were changed - then generally a calibration only flash will be sufficient. If however, any OS system "patches" were to be applied - this requires a "full" flash.
    Hope this helps answer your question ...
    Regards,
    Taz
    Jan 2011
    Yes it does .
  1. Flashing "over" another tune
    By MQ105 in forum Cummins 5.9L
    Last Post: June 27th, 2011, 08:13 AM
  2. Trouble flashing in a tune
    By Chris81 in forum FlashScan V2
    Last Post: January 4th, 2011, 10:03 AM
  3. Flashing different OS?
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2010, 10:00 AM
  4. re-flashing
    By s10mods in forum General (Petrol, Gas, Ethanol)
    Last Post: September 18th, 2007, 10:39 PM
  5. Flashing Tune went wacky
    Last Post: April 7th, 2005, 02:38 PM
