Results 1 to 10 of 16
Thread: change turbo vane postion at idle
    New Member duramax1861's Avatar
    Aug 2011
    Default change turbo vane postion at idle
    i was wondering how do you change the turbo vane position at idle to make the truck rumble rather than sound a vacuum cleaner. if anybody could help id appreciate it. i new to the efi live and am still learning little by little. i love it already though!
    2005 GMC 2500HD LLY R/C Longbed with banks 4 inch turbo back exhaust, banks intake, egt and boost pillar gauges and efi live by Nick at Duramaxtuner.com
    Aug 2011
    do a search on duramaxforum.com . I've seen a post on that there. My EFI
    Live comes today. I want to do the same
    Dec 2010
    set the idle areas (600-800 rpms and 0-10mm3 fuel) of the turbo vane position to 20%. Want more, go 5%. Wouldn't go any farther than that. 0% seems to have some side effects with it...
    Aug 2011
    which folder do you open to find the idle areas?
    Dec 2010
    The "idle area" is in the turbo vane table. Open up the turbo vane table (whichever altitude you are in) There are two axes, one for rpm, the other for fuel injected. When idling, the truck will run in between 600-800 rpms, and 0-15mm3 of fuel. Therefore, there will be about 6 cells in which the truck idles, and this is the idle area. If you still need help, let me know, and I will post a pic. Kinda hard tho as I am at work
    Aug 2011
    I'm still lost. Thanks for your time replying buy the way. I just got efi live. I'm using ver. 7.5. So under the calibration tab on the left I see engine ops, then boost control, then I see several turbo vane options. I don't any thing with altitude (I'm in Florida). Going to keep looking. Thanks Sid
    Dec 2010
    No problem, I enjoy helping others out. Send me an email at andrewjamesbond1@gmail.com and we will get you straightened out!
    Aug 2011
    Thanks for helpin guys. I appreciate it.
    Dec 2010
    Did ou get it figured out?
    Aug 2011
    No not yet. Haven't had time from work to do it.
  1. Turbo Vane Target Position Question
    By dieselz28 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 21st, 2010, 12:38 AM
  2. LMM-Turbo Vane Target Position
    Last Post: January 23rd, 2010, 06:31 AM
  3. Min. turbo vane position?
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 9th, 2007, 10:56 PM
