Results 1 to 10 of 15
Thread: Cos5 boost and MAF
    Sep 2007
    Default Cos5 boost and MAF
    Hi
    I am preparing for an E-force supercharger on my LS3 Impala clone. I have used the 12212156 os, and have now switched to cos5.
    Can I use the MAF sensor on this os when using the boost ve table and a 2 bar MAP?
    Is cos5 the best os that I can use with boost and this PCM?
    Is this pcm suitable for this application or should I go for a newer pcm?
    Tor
    May 2008
    Same PCM and OS that I am using, and yes, you can use the MAF with COS5.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Nov 2007
    The 12200411 PCM takes a 24x crank signal and the LS3 has a 58x crank reluctor.
    -Justin
    May 2008
    Hmm, for some reason I just assumed he already had it working.
    48 LB injectors
    T70 turbo.
    LPE sells a module for converting 58x/4x to 24x/1x.
    Nov 2007
    OH that's right, it only lowers the resolution.
    I don't see any problem with keeping that PCM. What is an LS3 Impala Clone (1996 Caprice ??)
    It actually converts the CKP signal from straight 60x (with 2 missing pulses) to encoded 24x (encoded sequence of 12° and 3° pulses), and reduces the resolution on the CMP signal.
    Nov 2007
    What I meant was you can't go from a 58x PCM to a 24x Engine.
    Ah, I see now what you said, ignore my comment
    Sep 2007
    Sorry for simplifying to mush.
    The car is originally a 91 caprice and for now it is just the interior that looks like the original car.
    It have an Gm performance parts LS3 engine, 2002 f-body engine controller, wiring harness and accessory, Lingenfelther 58 – 24 conversion box, 4L60E transmission. The engine was installed last year and has been running 15000Km as my daily drive.
    I have bought an Edelbrock E-force supercharger kit for a 2010 Camaro that I am going to customize for the car. Now I am waiting for a 2010 Camaro front accessory kit from Pace to fit the supercharger. The pulley on the supercharger is ¾“ longer from the block then the old 2002 Camaro front accessory.
    I have converted from 12212156 os to cos5 and are test driving it now, before I start installing the compressor.
    My question is actually if this os are the best to use with this engine compressor combination, or if it is other combination that is better suited. The car is my daily drive summer and winter
    When I look at the Cos1-3 tutorial it seems like I can’t use maf and 2-3 bar map at the same time? Is this true?
    Tor
Name:	DSC_0118 as Smart Object-1.jpg
  1. Boost leak MAF Reading
    By lownslo in forum Gen III V8 Specific
    Last Post: October 16th, 2009, 01:40 PM
  2. Replies: 10
    Last Post: August 27th, 2009, 10:38 AM
  3. MAF Calibration..Why not use SAE MAF vs CYLAIR DMA
    By WeathermanShawn in forum Gen III V8 Specific
    Last Post: September 30th, 2008, 10:44 PM
  4. Use MAF for off boost/2 Bar SD when in boost
    By Earl H in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 24th, 2007, 12:58 PM
  5. Set MAF limit to 1Hz, but MAF still working?!?!
    By TaTommy888 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2005, 07:02 AM
