Results 1 to 10 of 18
Thread: will not log now
    Mar 2007
    Default will not log now
    Just updated to the newest version of 7.5 and 8 listed on the download section so that I had the efilive explorer to retrieve logs from my v2. after installing update and updating firmware and boot i went out to the truck to test log again. It is only logging 1 of 30 or so pids. v2 will not scan or record correctly. i am sure that i forgot something simple. any thoughts?
    Hi Paul,
    Did you configure BBL using the V8 S&T program for the pids you want to log...?
    Mar 2007
    I went into the s&t and selected the pids that i want to log. The pids are showing up on the v2 when i attempt to log, but they all stay a 0 or unknown except 1. Is ther other configuring that i need to do?
    What is the version of the firmware in your V2...?
    Which year/model/vehicle...?
    Mar 2007
    Updated the firmware to 2.7.14 that was with the update. i updated the firmware and bootblock through the efilive explorer. Truck is 2007 chevy duramax lbz. E35 and e40 iirc. After the update i pulled the tune off of the ecm and reloaded it with my laptop. That seemed to work fine.
    Paul.
    It works now...? Cool
    Mar 2007
    It seems to work when i use my laptop, but i cannot bb log.
    Mar 2007
    I think that I have done all of that, but I will double check. BBLogging was working before i upgraded, but I did not have the EFI explorer to look at the logs.
    Is there a way to see what version of bootblock and firmware were loaded prior to the last update. The last time I updated was the spring of 2009 i believe. Perhaps I needed to update the bootblock and firmware in steps.
    Use V8 EFILive Explorer (EE) to view bootblock/firmware versions, report back what they are.
  1. take a look at this log
    By BadLSX in forum Gen III V8 Specific
    Last Post: October 26th, 2010, 12:27 AM
  2. what to log?
    By Boost in forum Duramax LLY
    Last Post: September 19th, 2010, 09:35 PM
  3. New log. What next?
    By sinr98 in forum Gen III V8 Specific
    Last Post: November 4th, 2009, 07:38 PM
  4. What's going on here?- log
    By DrX in forum Gen III V8 Specific
    Last Post: September 27th, 2009, 09:29 AM
  5. How can I log
    By Rusty in forum Gen III V8 Specific
    Last Post: December 29th, 2006, 01:53 AM
