Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: will not log now
  1. #11
    Mar 2007
    Bootblock 2.07.02 firmware 2.07.14
  2. #12
    Oh, silly me there is no way to know what your V2 firmware version previously was.
  3. #13
    Try this:
    - install V7.5.6 build 175 from here: Pre-Release-Update-July-29-2011
    - install V8.2.1 build 165 from here: Pre-Release-Update-July-29-2011
    - install bootblock 2.07.03 into V2 using EE,
    - install firmware 2.07.18 into V2 using EE,
    - format the config space using EE,
    - format the data spaces using V2 keypad (do you have an SD card...?),
    - create a new pidlists for your PCM using S&T, and program these to your V2.
    Then at your V2, select the pidlist you want to log and see if you can log.
  4. #14
    Mar 2007
    I will give it a try. Do i need to uninstall the builds i have now or can i install them "over the top"?
  5. #15
    Mar 2007
    Try this:
    Thanks, I read through the updates and it shows a fix for BBL not starting when logging LBZ and A 40 logged simultaneously. That seems exactly like what it was doing. I should have been more clear in my original issue post. I am trying to log the ecm and tcm at the same time.
    Thank you for your help, I will give this a shot this evening and report back on the progress.
    Mar 2007
    I had a chance to try the latest update and it seems to be working properly. Thanks alot for your help.
    You got BBL working...?
  8. #18
    Mar 2007
    yes i did. i used the update that you listed in your previous post. I have not had a chance to pull the log from the v2 to look at it, but the v2 was acting correctly both recording a log and viewing the data.
    thanks
  1. take a look at this log
    By BadLSX in forum Gen III V8 Specific
    Last Post: October 26th, 2010, 12:27 AM
  2. what to log?
    By Boost in forum Duramax LLY
    Last Post: September 19th, 2010, 09:35 PM
  3. New log. What next?
    By sinr98 in forum Gen III V8 Specific
    Last Post: November 4th, 2009, 07:38 PM
  4. What's going on here?- log
    By DrX in forum Gen III V8 Specific
    Last Post: September 27th, 2009, 09:29 AM
  5. How can I log
    By Rusty in forum Gen III V8 Specific
    Last Post: December 29th, 2006, 01:53 AM
