Results 1 to 10 of 12
Thread: AutoCal Modes?
    Aug 2011
    Default AutoCal Modes?
    What does Full 1 full 2 ..etc mean? How is it different from Prog 1...etc??
    This was posted previously by someone else, but was never answered.
    The quick start guide does not discuss the 'Full' modes.
    Thanks,
    Jason
    Jul 2004
    I believe it's full flash versus calibration only flash.
    Ira
    Aug 2011
    How is it different from 'Prog' ?
    Jul 2004
    Well, I assume prog is Calibration only.
    Ira
    Oct 2004
    Just updated the documentation. The 'Prog' options are calibration only flash operations which should be performed under normal circumstances (unless directed by your tuner). The 'Full' options are full-flash operations and download both the operating system and calibration data to the ECM/TCM controller.
    Andrew
    EFILive Crew
    New Member JPaupst's Avatar
    Apr 2012
    So when not using a DSP tune and only trying to use the Autocal for individual tunes one would hook it up to the truck and just tune with the "program 1" and not full flash as im assuming full flash is for DSP tunes , correct?
    Depends, if LLY/LBZ/LMM then you can cal-flash, LB7s need a full reflash every time for DSP tunes.
    For non-DSP tunes, calibration only flashes are all that is required to change the tune (unless you're changing the OS).
    Apr 2012
    Its an LBZ. So i can only do the full flash and not the cal flash or whatever it is? So is that just prog 1-5 or does it say full flash 1-5? sorry newb here still waiting for my tunes but wana be ready when i get them.
    2006 Chevy Silverado 2500HD LBZ Allison 1000
    5" Magnaflow Turbo Back w/ K&N Intake
    Cognito 4" NTBD on 33" BFG's w/ H2's
    EFI Live Autocal with custom IdahoRob Tuning
    Moderately Modified
    Oct 2004
    So this is how it works out. A cal-flash is performed generally for all ECMs except an LB7 with a DSP5 installed. The cutom tables on the LB7 DSP5 didn't all fit into the calibration memory area and overflowed in the OS area, thats whay afull-flash is required when changing a LB7 DSP5 calibration.
    You're fine with an LBZ to do cal-flashes.
    Andrew
    EFILive Crew
    Apr 2012
    So even though im not using a dsp switch and tunes and am only running individual tunes it is still fine to just cal flash?
    Moderately Modified
  1. switched modes??
    By truethinker in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 16th, 2012, 02:03 PM
  2. Setting up the N2O Modes
    By BowlingSS in forum Custom Operating Systems
    Last Post: January 25th, 2008, 05:35 AM
  3. Knock modes
    Last Post: October 26th, 2006, 06:08 AM
  4. Need tables for limp modes
    By bobo in forum Duramax LLY
    Last Post: October 18th, 2006, 12:57 AM
  5. What do the different TCC modes mean?
    By thunder550 in forum General
    Last Post: May 6th, 2006, 10:36 AM
