Results 1 to 10 of 13
Thread: new injectors cant get past 100mm3 now
    Jul 2011
    Default new injectors cant get past 100mm3 now
    So I recently upgraded my injectors from my old set, with my old tune I was able to achieve 160mm3 up to around 3500 or so befor eit would fall down to about 130 at 4000. I have since installed the new injectors took truck out logged it and now it max's out at 100mm3 at 3500 on every single log I do. no matter the tables I modify.. I did just swap a stick into the truck vs the auto.. one thing I noticed was with the other trucks Ive tuned I cannot get the load% on a log to go past 40% with a stick where the auto's I have seen 110% in some logs but mostly 99-100% they all carry 160mm3 through the run to about 3400. does load have a effect on the mm3? The truck actually runs better with new injectors at 100mm3 than old injectors at 160mm3. I understand that its just a quanity expression but the injectors I put in new are smaller.. so wouldnt I want more mm3?
    Jun 2011
    What is the flow rate on old vs. new injectors? Did you have the return rate checked on the old injectors?
    Jul 2011
    You want lpm? over over % these are 175% over nozzles I had 2 bad injectors on the last set they were replaced and new nozzles added to this set. these were made by exergy
    Jul 2011
    sorry kinda misread your post, I will get my charts out tonight from exergy on rates. Its just weird that it all of a sudden wont achieve more that 100mm3... It might be the fact that the trucks getting lost at 3500 with the auto map.. Im going to try a manual map tonight and Ill let you guys know.
    Jul 2011
    Got it figured out have to start out with manual tune. I have 156mm3 to 4200 then drops to 136 at 4300 then I let out..
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    Good to hear. Wonder what the culprit was. Defueling, waiting for a shift I suppose.
    Spray & Pray
    Jun 2011
    Quote Originally Posted by 06dodgecr View Post
    How much duration are you seeing at 4200?
    Jul 2011
    Ill check the log out tonight. let you know
    Jun 2011
    Dam right u will!
    Spray & Pray
    Jul 2011
    Just checked it out my duration falls to about 1700 but that's what it commands when the mm3 starts to fall like that by 4300 I'm down to 86mm3. I'm going to try a new tune tom. It's got diff fp axis and max command on mpa I raised to 180.
  1. Need help on 99 454, cant rev past 4800
    By mathis in forum Vortec V6/V8 Specific
    Last Post: April 9th, 2011, 07:49 AM
  2. Revving past 8000+ rpms
    By robz in forum Gen III V8 Specific
    Last Post: November 15th, 2009, 08:51 AM
  3. Rail Pressure past 3000 RPM
    By JoshH in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 20th, 2008, 01:38 PM
  4. LS2 Transplant won't go past idle.
    By Scoota in forum Gen IV V8 Specific
    Last Post: April 20th, 2007, 05:57 PM
  5. 96lb/hr injectors can be run like stock injectors with EFILIVE!!
    Last Post: July 24th, 2006, 03:14 PM
