Originally Posted by
Rhino79
Be sure not to go to overboard with shift times. With these being totally different than the 4-speeds, they do require SOME shift timing in there. Shift timing and pressures seem to be key. MPH and RPM have to be dialed in correctly for precise wot shifting. Adaptive learning needs to be left on, it actually helps these transmissions learn and shift better. Reflashing the tcm does NOT appear to clear the adaptive learning trims, so they need to be 0'd out in the scan tool to ensure it isn't running on old trims causing some funky shifting. I have my shift times setup at about .25 sec, and I have a nice firm quick shift without being violent. I have raised the pressures a bit at a time, until I got the feel I wanted.
