Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Clutch fan removal way to disable ses light?
    What OS? Unfortunately some P10 OSs dont work like they should in EFILive, either have to upgrade the OS or use HPTuners to do it.
    Post your file as well, are you only getting the P1481 code?
    Apr 2013
    I'm pretty new at this so pardon my inexperience. How do I tell what OS I have?
    The only code I've seen is the P1481.
    In addition to removing the fan, I also tried to resolve a surging issue with the torque converter. My first attempt at tuning is attached.
    2003 trailblazer LTZ - 269000 miles and counting. . .
    To find your OS, open the tune file. It will be listed in the first window that appears, yours is 12588012.
    Why did you turn VATS off? Unless this is a transplant, messing with those values will cause some weird issues.
    I have made a few changes (compare this one to the one you uploaded to see them), try this out. If it doesnt kill the P1481 try adjusting G1021 to like 8 volts, different OSs treat this value differently.
    Once you get more comfortable with the software, if you have a V2 use Scan & Tune V8 to flash. Takes much less time and the routines are more robust, Ive had some issues programming P10s with V7.5 but none using V8. However, if you have a FlashScan V1 you have to use V7.5.
    Apr 2013
    Thanks for the help!
    I turned VATs off just to see if it made a difference. It didn't make any difference.
    I've been using scan and tune V8 to load onto the PCM. When I first tried V7.5 it would down load the PCM but wouldn't load back to it. It took me a little time to figure out to use the V8 version to get it to work.
    I loaded the new program and the error code (P1481) still came up. I then changed G1021 to 8v and the error code still came up. To get the code, I start and run the engine for about 10s. I shut it off, restart, and run for another 5s or so before the MIL turns on with the code.
  1. Replies: 6
    Last Post: January 4th, 2012, 10:46 AM
  2. Service brake system w/ABS light and Parking Light on
    By mshirshe in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 13th, 2010, 02:32 AM
  3. Clutch Relearn?
    By Chalky in forum Gen IV V8 Specific
    Last Post: March 16th, 2009, 12:08 PM
  4. help ses light
    By warscout2 in forum Gen III V8 Specific
    Last Post: September 11th, 2008, 03:08 AM
  5. VT Mil Light & Fan
    By saeb in forum EFILive V4
    Last Post: March 11th, 2006, 08:01 PM
