Results 1 to 10 of 11
Thread: few questions
    Jul 2011
    Default few questions
    a couple questions for you more experienced guys. first, im trying to look at my flashscan firmware programmer for the v7.5 and it keeps tellin me that im in dead poll or when its connected to the truck, it says "cannot connect to flashscan v2. a device attached to the system is not functioning. win32 error: 31? firmware is ok for the v8 and i can log and tune with the v7.5 software? maybe im just missing something? i checked all this after i had downloaded the july 31st pre release and didnt have the new tables (E2536 and E2567) when i opened up the tune tool. my other 2 questions are, my fuel pressure reg.base duty cycle table (D0790) is set at 0% at 0 rpm and goes up to 36%. should that be adjusted throughout the rpm range staying at 0% at 0 rpm and increasing say up to 90-100% at 3500 rpm? also, my Fuel Pressure Reg, Max Duty Cycle % (D0791) is set at 71% from 600-3500 rpm. can i change that to 100% for the whole rpm range? sorry for the long post. hope someone can shed some light on this. thanks
    denny
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Hi Denny,
    On the V2 side of things... make sure you have downloaded v7 and v8.. then go to efilive HAPI and from there you will be able to see what firmware and bootblock your flashcan has... if there is a update necessary for it it will tell you to update it.. on the reg max duty cycle,, many guys have left this table alone, but 100% in the upper rpms will do the trick :-)
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Jul 2011
    thanks for the quick reply man. i reinstalled the 7.5 and 8 pre release again this morning, checked the firmware and it was all up to date in HAPI and did a manual search for updates. still the same results. kinda throwing me for a loop. just to make sure where clear, leave D0790 alone and adjust D0792 up to 100% in the upper range or vise versa? sorry, still learning and don't want to mess something up. not the most computer savvy either. thanks again
    denny
    Jul 2011
    guess i'll just wait for the next release next week. hopefully it will fix my problem
    Jun 2011
    Quote Originally Posted by olboyowl View Post
    Here? http://forum.efilive.com/showthread....-2-Aug-19-2011
    Jul 2011
    oh, sweet. didn't know it was out. thought i read next week. thanks man. unfortunatley im at work and cant get internet access on the laptop. just double checking, alls u have to do for the manual download is: download the new software, save it to the computer, open it up and run the program and your set, correct? don't want to miss somthing. like i said earlier, not to computer friendly. thanks again for the help
    Jun 2011
    No prob!
    Yes, sounds like you are in the right direction for downloading the new stuff.
    Lifetime Member FUBAR's Avatar
    Feb 2011
    I think Ross may have meant next week would be an "Official" release whereas realease candidates are more or less pre-releases that are safe to use for professional tuners tuning multiple trucks. At least that's the way I like to think of it.
    06 LBZ, EFILive
    Jul 2011
    Quote Originally Posted by chizwizdiz View Post
    No prob!
    thanks, thought i did it right.
    Quote Originally Posted by FUBAR View Post
    is that why i didn't have the tables when i downloaded the july 29th pre release? that would make sence.
    Jul 2011
    downloaded the august 19th updates and still dont have the new tables? am i supposed to select "no" when it asks me if i want to keep my existing registry settings and reset the property settings to factory default? ive been selecting yes and keeping my existing registry. sorry for askin so many dam questions.
    denny
  1. LMM DSP questions / Power questions
    By Djreversal in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 18th, 2011, 08:06 AM
  2. 3 questions
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: October 22nd, 2010, 02:46 AM
  3. Few questions.
    By Devil_Z in forum EFI University
    Last Post: May 24th, 2010, 04:56 PM
  4. A Few Questions
    By JAHII in forum Gen IV V8 Specific
    Last Post: December 21st, 2009, 05:45 PM
  5. 2 questions
    By ls1transam346 in forum Gen III V8 Specific
    Last Post: September 4th, 2007, 05:33 AM
