Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: 6.7L ECM & TCM Reading
  1. #21
    Dec 2006
    Quote Originally Posted by pedro1141 View Post
    So 2010 rams are not included in the reading?
    No not yet, I believe I saw that the 2010 and 2011 had some sort of encryption.
    I am waiting for the 2011 and I have a 2012 on order.
  2. #22
    The encryption apparently applies to some 2009's as well.
    At this stage don't bother trying to read the 2010+, it's a different ECM to the original 6.7L one.
  3. #23
    Sep 2011
    So will the 2010-12 be next?
    2010 ram 2500 4x4 6.7L, 3" lift all around, 35" Toyo MT
  4. #24
    A bit of a wild guess, but the 2010-2012 will not be looked at until 2012. I am away for all of November so nothing will happen with R&D during that time, up to that point (and probably beyond) we'll be working on the pre 2010 6.7L.
  5. #25
    Oct 2011
    When did this changeover occur or how does one tell if they have a readable or non readable ECM ?
  6. #26
    Lifetime Member AFTERMATH DIESEL's Avatar
    Apr 2011
    Quote Originally Posted by someguy View Post
    Build date of 3/09 or later I believe I'm sure some one will chime in.
    Aftermath Diesel Service
    888-494-0019
    Chris Klenke
    Cummins beta tester/EfiLive authorized reseller
    2007 5.3L Suburban and a 2015 Ram 2500 that's stuck on a train
  7. #27
    Oct 2011
    Quote Originally Posted by MOTuner636 View Post
    Is that the truck build date or the engine build date ?
  8. #28
    Lifetime Member DoghouseDiesel's Avatar
    Dec 2009
    Truck build date or any ECM that was flashed by the dealer after that data with the boot loader security.
    If it was flashed by the dealer, normally there's a sticker on the upper radiator support showing the ECM flash.
    1207 HP / 1612 TQ
  9. #29
    Oct 2011
    Once its flashed by the dealer, can someone reflash it to a previous version (with EFI Live) ?
    Thanks !
  10. #30
    Oct 2011
    Any updates on the release of the early 6.7 stuff?
  1. ECM, TCM, PCM & BCM Issues Who's the Expert
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 7th, 2008, 01:30 PM
  2. reading Problem ( LC-1 logwork & gage & EFIlive )
    By Ls1_Rulz in forum FlashScan V2
    Last Post: October 17th, 2008, 06:42 AM
  3. error reading TCM
    By 98TJ in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 1st, 2007, 04:03 PM
  4. problem reading allison 6 speed TCM
    By Samdogmx in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 5th, 2007, 12:00 PM
