Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 73
Thread: Release Candidate 2, Aug 19, 2011
    Quote Originally Posted by etmotorsports View Post
    14:56:44.808: USB driver version: 2.8.20
    14:56:44.808: USB library version: 3.2.4
    Looks like the USB driver and USB library files installed on your system are not compatible.
    You should see:
    09:31:06.531: USB driver version: 2.8.20
    09:31:06.532: USB library version: 3.1.18
    Is it possible that you have software installed from a different vendor that also uses the FTDI USB drivers and that software has installed a later driver version?
    If you do have other software that requires a later version you may need to install the latest FTDI USB drivers for EFILive using the program:
    Start->All Programs->EFILive->V8->Tools->USB Manager.
    Or you could try going back to the earlier version of the USB drivers using the same USB Manager program.
    Dec 2006
    Installed and working ok so far.
    Jul 2011
    I'm getting a 0185 code when trying to read in scan and t
    une??
    Dec 2006
    Quote Originally Posted by 06dodgecr View Post
    une??
    What vehicle are you having a problem with?
    Lifetime Member 06redram's Avatar
    Jan 2011
    Updated instructions for installing updated software/firmware:
    Download and install V7/V8...
    then using V8 EFLive Explorer do this:
    - goto thew Firmware tab,
    - update the bootblock to 2.07.03,
    - update the firmware to 2.07.21,
    - exit from EE.
    then using V8 Scan & Tune do this:
    - goto the BBx tab,
    - goto the Scan subtab,
    - click Read,
    - click Save (and if asked specify filename Options.txt),
    - click the down arrow on the Program button and select Format Config File System,
    - click the down arrow on the Program button and select Program All Required Data (Slower),
    - exit from the subtab and exit from S&T.
    Also, using V8 Scan & Tune, do the same on the Devices subtab (filename is Settings.dat).
    I can not find the firmware to 2.07.21 only, 2.07.19
    Dec 2006
    In V8 Explorer, Go to the firmware tab:
    Click on the Browse button
    Go to C: drive
    Go to Program files x86 for 64 bit systems, Program Files for 32 bit systems
    Go to EFILive
    Go to V8
    Go to firmware
    Jan 2011
    I will try that! I will post back
    Jul 2011
    06 cummins
  9. #19
    Oct 2006
    Install over the top of last release or remove before install ?
    2006 Trailblazer
  10. #20
    Dec 2006
    You can install right over the top. It will over write all the files.
    Do not use the check for update, as it will mess up the install.
  1. Release Candidate 1, Aug 04, 2011
    Last Post: September 11th, 2011, 03:36 AM
  2. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
  3. February 26th 2011 release candidate 1
    Last Post: March 4th, 2011, 09:55 AM
  4. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
