Results 1 to 6 of 6
Thread: lly.pmm file
    Aug 2011
    Default lly.pmm file
    anyone know why I can't find the lly.pmm file?
    I believe it has been renamed to E60.
    Oct 2004
    Correct Joe. Quite a while back the V8 software was change to refer to the controllers by their proper name. The following changes occurred (from memory):
    - LB7->E54
    - LLY -> E60
    - LBZ -> E35A
    - LMM -> E35B
    - AL5 (no change)
    - AL6 -> A40
    Andrew
    EFILive Crew
    Aug 2011
    Thank you , thank you. I was following a sticky on another forum. Which must be old. Trying to use my v2 as dsp5. I'm also a newbie that's overwhelmed. Thanks again
    Oct 2011
    i cant seem to find any lly.pmm or e60.pmm files or al5.pmm did i not load somthing? im at a stand still and lost with this
    Aug 2011
    In explorer, open v8 folder, then config.
  1. 05 LLY Help
    By jarasic in forum Diesel
    Last Post: August 9th, 2010, 09:17 AM
  2. PMM file question
    By 860 in forum FlashScan V2
    Last Post: March 24th, 2009, 12:57 PM
  3. Missing PIDS from LS1B_M.pmm
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: October 3rd, 2008, 06:56 PM
  4. LB7 / LLY .cal file update - 08-Jan-2008
    By GMPX in forum General (Diesel)
    Last Post: January 13th, 2008, 09:56 AM
  5. Stock LLY file?
    By Wasted Income in forum Duramax LLY
    Last Post: December 25th, 2005, 04:27 PM
