Results 1 to 2 of 2
Thread: Crank angle sender
    Aug 2011
    Default Crank angle sender
    Ok, here is the story. I have a 350 vortec crate engine, bought as a carby version. I am using a crank trigger distributor and so had to retro fit a reluctor / sender to the motor. Had trouble finding a pig tail for the sender so the fix was to fit three individual wires and fill the socket with glue, easy. Now I know the sender has +12V, signal and ground but wich is wich I dont know !. I believe the middle one is the signal and i suspect the bottom is +12V and that leaves the top as ground ?. Can someone confirm my suspisions ?.
    Aug 2011
    Quote Originally Posted by RXP855 View Post
    Is anyone able to take a look at the sender on their motor and let me know the orientation of the wires on the sender ?. Should be pink, yellow and purple. All I need to know is what color is at the top, middle and bottom of the plug when it is installed in the timing cover. Anyone ????.
  1. How does the PCM calculate throttle angle from B4307 ?
    By DrX in forum Gen III V8 Specific
    Last Post: July 9th, 2011, 01:51 AM
  2. crank angle sensor error
    By kostelacd69 in forum Custom Operating Systems
    Last Post: May 28th, 2010, 08:21 PM
  3. learn crank angle sensor error
    By Dottry in forum General
    Last Post: October 10th, 2008, 05:16 AM
  4. A new angle (crank that is)
    By Spindoctor in forum Gen IV V8 Specific
    Last Post: March 13th, 2008, 08:46 AM
  5. Replies: 6
    Last Post: July 28th, 2006, 02:46 AM
