Results 1 to 4 of 4
Thread: Description of DTC's no longer available
    Nov 2008
    Default Description of DTC's no longer available
    When I did my latest update I lost my descriptions when I read DTC's. Now it just gives me the code but, no description. It happened with the update that allow us to read cummins dtc's. I remember doing something to put the descriptions in there but, I do not remember what. Is this a common problem or did I do something wrong?
    Start the V8 S&T program, click F5:BBX, click F5:DTCs, click Read, checkmark the Chrysler DTC's, click Save (if asked specify filename Options.txt), click Program, click Close, exit program.
    Nov 2008
    Thank you I did that but was unable to add all the GM and Chrysler DTC's because it said I was over 100% of memory capacity.
    Format the config space (this deletes all the files) and re-program the files...
    before you do that, delete any pidlists and any ECM's that you don't use from each of the Scan and Tune subtabs.
  1. Is this right? D0914 Description
    By nevinsb in forum General (Petrol, Gas, Ethanol)
    Last Post: July 5th, 2009, 09:38 PM
  2. Access DTC description list?
    By Trippin in forum General (Petrol, Gas, Ethanol)
    Last Post: August 26th, 2006, 08:16 AM
