I'm following the pdf for the dsp5 upgrade and when formatting the 3 files in efi live explorer the v2 says formatting. Then after that I go to select pids and the v2 says no options,txt found. How come these aren't being copied to the v2?
Ok. I found a tutorial and I now have the options.txt install in the bb. I can't find at this point how to put my tune in the switchable tune.
Install V8, then use EFILive Explorer to copy your tune into the Tune folder. Also use The V8 Scan and Tune BBX pages to tell it what controllers you want to read and flash.
Ira
