Results 1 to 7 of 7
Thread: MAP Sensor O-ring
    Aug 2005
    Unhappy MAP Sensor O-ring
    Does anybody know the part number of the MAP Sensor O-ring or where I can buy a similar replacement? I knicked mine when switching to the 2bar sensor and it's causing a vacuum leak. Did it a while back, but just dawned on me why my autotune is solid in SD mode but lean under heavy vac and rich under boost when I re-enable the MAF.
    Thanks for the help
    EDIT: Nevermind, stumbled on it. 16194007
    Oct 2003
    It is a known problem on the FAST intakes as well.. You can bed it in with Silicone.
    PowrMax Performance
    100 mm PowrMAF
    Find some generic o-rings of the same diameter and cross-section at your local parts store.
    Aug 2005
    It's not a standard O-ring, per se. I think the only way to get a proper seal would be with the proper seal or with a good amount of Silicone.
    I tried looking up this o-ring, and it is not shown as a separate part (F-body parts PDF);
    it has no part number and seems to only come packaged with the map sensor;
    this is just ridiculous.
    Aug 2005
    Doesn't even come included with purchase of a new map sensor. Go figure. I just ordered a couple of them from a dealer in Texas. Around $2.50 each.
    Aug 2005
    I siliconed mine and made a hold down from .062" X 1.0" Aluminum. I bolted it to the intake under that fixture for the knock sensor plug.
    Dale
    78 Datsun 280Z W/LS1/T56
    TR230, Absolute Speed stage II 5.3 heads, Fast 90mm setup, JTR 1 3/4 headers.
  1. 2.5 bar map sensor
    By 02SSLE in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 17th, 2010, 10:50 AM
  2. Anyone know of a 1.5 bar MAP sensor?
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2007, 08:57 PM
  3. A severely burnt ring..
    By ringram in forum Lounge
    Last Post: June 9th, 2006, 11:09 AM
  4. O2 Sensor help please...
    By Fixer in forum General
    Last Post: October 22nd, 2005, 02:51 AM
  5. 2 Bar MAP Sensor
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2005, 12:28 AM
