Results 1 to 4 of 4
Thread: E38, 427 LS7 Hard Crank
    Sep 2010
    Default E38, 427 LS7 Hard Crank
    Hey guys, I have a car here with a 427 and a pretty healthy cam that will not fire up unless I manually open the TB with the gas pedal. Fuel on crank is spot on as well as crank airflow...is there another table I am missing?
    Paul Meister
    EFI Calibrator/Managing Member, Torq Speedlab, LLC
    Specializing in late model Ford, GM and Dodge EFI Calibrations
    SCT, EFI Live, HP Tuners, FAST, BS3 and much much more
    Dec 2007
    Quote Originally Posted by Meister View Post
    How are cranking fuel and airflow "spot on" if it wont start?
    Dec 2007
    can you log and see what airflow, throttle position, and injector pulse are doing on cranking?
    David McLain
    www.etdrag.com
    Jul 2007
    Post the tune.....
    But at a guess, try increasing {B1832} a bit. Add 20% across the board as a test, maybe even try 50%
    Simon.
  1. E38 Hard Limits? Hitting a brick wall at 7059RPM???
    By Meister in forum E37, E38 & E67 PFI ECM's
    Last Post: June 16th, 2012, 06:10 AM
  2. Advice:427 supercharged LS9 injector/LS7 MAF
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: May 2nd, 2010, 03:25 PM
  3. Need help! with OS for 2010 E38 on LS7
    By USA Z06 in forum E37, E38 & E67 PFI ECM's
    Last Post: February 2nd, 2010, 12:57 AM
  4. E38 Crank Position Sensor Relearn
    By hapnermw in forum Gen IV V8 Specific
    Last Post: May 2nd, 2009, 04:58 PM
  5. E38 5.3 LMG Crank relearn
    By harascho in forum Gen IV V8 Specific
    Last Post: December 4th, 2008, 08:04 AM
