Any news on the new PW limiter public release?
Jake
I'll have to check with Paul when he plans on doing another update, however, he has been rather ill this past week so things have ground to a halt in that area.
On the additional pulse width, what is out there now (D0511 set to minimum) will get you sorted to about 3,300RPM, the new addition that was given to the beta testers is for RPM's beyond that whilst requesting 3,000uS+ injection times.
Congradulations to EFI Live & Starlite Diesel...Good work guys...
2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
I missed this one, awesome news!
That thing sounds nasty, how much defuel are you running for the shifts? Looks like a lot! Sounds a little like the 4.2L I6 in my TrailBlazer, probably because they're both I6s. Mine revs to 6500 with EFILive, but I know it doesnt make half the power that Cummins is making...
Guess anyone who wants to be competitive with a 5.9L Cummins needs to be running EFILive otherwise they have no chance. Have fun at the track this weekend everyone.
Well so far the 6 speeds seem to be holding up much better than the autos - provided they have a good clutch in them. The stockers arent much good for anything too far beyond stock power levels apparently... but the transmissions really seem to take a beating on all the trucks i've worked on so far....
2005 Crew Cab Dually Duramax
Big turbos, big injectors, big pumps, crazy heads AND a flux capacitor...
Best run so far on street tires: 11.14 @ 128.8 mph
Stock dodge nv5600 are good to about 900hp pretty reliably. The stock g56 are good to about 600hp reliably, these are aluminum housed and are only good if proper gear is selected. They hate being lugged. Stock autos are carp as usual.
Jake
