Results 1 to 3 of 3
Thread: Hard Downshift, lb7 dsp 5
    Aug 2011
    Question Hard Downshift, lb7 dsp 5
    I have a 2004 LB7, I installed a DSP 5 switch, a knowledgeable friend of mine installed several custom EFILive tunes: 1 = Stock, 2 = Loop, 3 = Smoke, 4 = Power Tune 1 and 5 = Power Tune 2. After installing the tunes the truck down-shifts really hard and clunks even harder 4-3, 3-2, 2-1, We have adjusted everything we can think of to smooth it out with no luck! Any ideas, suggestions or help is much appreciated.
    Feb 2010
    Hello!
    If you made full flash, trans is relearning for a while, I think
    LB7 2001, EfiLive DSP5 , AirDog II, Afe intake , Summit 4"exhaust
    Dec 2010
    Quote Originally Posted by hecatti View Post
    Hello!
    Agreed, give the ally a chance to relearn. go easy on it the gradually ramp up the throttle each time you go from 0 to cruising speed.
  1. lb7 dies after dsp-5 flash
    By anarchydiesel in forum Duramax LB7
    Last Post: August 29th, 2011, 03:37 PM
  2. dsp 2 switch not working on 01 lb7
    By mpeters0991 in forum Duramax LB7
    Last Post: January 7th, 2011, 08:38 AM
  3. 03 lb7 dsp 5 w/problems
    By audiodynamix199 in forum Duramax LB7
    Last Post: May 14th, 2010, 02:13 AM
  4. Brake downshift
    By L31Sleeper in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 18th, 2010, 05:31 PM
Tags for this Thread
