The tutorial Gives the following instructions:
Set the
Engine Diagnostics->Engine Diagnostics->MAF->Parameters: • {C2901} MAF High Frequency Fail 1: 1Hz • {C2902} MAF High Frequency Fail 2: 1Hz If calibration {C2902} is not available in the operating system that you are using, then ignore this step. • {C2903} MAF High Frequency Fail Limit: 1 • {C2907} MAF Test Min Engine Speed: 300 RPM • {C2908} MAF Test Min Run Time: 0.1 seconds
It appears to me that this will only result in a MAF fail if the MAF is still plugged in as the MAF frequency will never be equal to or greater than 1 if it is unplugged. Would it not be more appropriate to set C2904 to 20000 and C2906 to 1 if the MAF is permanently removed so that SD mode is triggered immediately?
