Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: T43 2010 2011 Missing Base Shift times and Diags
    Dec 2007
    Default T43 2010 2011 Missing Base Shift times and Diags
    Are the base shift times and diagnostics section supposed to be missing from '10 and '11 T43 trans tunes?
    Yes, it's no mistake, I just haven't had time to add them in for all OS's. I'm pretty sure there is some done though.
    See here: http://forum.efilive.com/showthread....012-T43-Tables
    Dec 2007
    Oki doki. Just a matter of time then more pouring through that TCM designed by Aliens? Or maybe more to the point programmers sipping beer from breakfast throughout the day (seriously they do!).
    Quote Originally Posted by gmh308 View Post
    And inspiration
    Dec 2007
    And inspiration
    Er...just imagine they were the trans supporting an oiler
    I could imagine my car is a new Maserati Quattroporte Sport GT, but it's not.
    Dec 2007
    Only if you look at it. Until you look at it, it is a Maser. Its a quantum concept . Joe can advise further.
    Like the shift timing calibrations...they are definately there, until you look for them, then you find they are not. But they are.
    lol... from Physics class:
    it has a non-zero probability of being there until you look for it... ...the act of looking for it messes it up.
    Dec 2007
    And when you look at it the probability that it will be there when the light that represents it leaves it, approaches zero at the speed of light squared.
    So dont look, and one's dreams are realized. The fact you cant drive it is a minor technicality, or quantum paradox.
    I must not be smoking the same thing you two are
  1. 2010 Camaro 6L80 desired shift times
    By 2010 Bumblebee in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 5th, 2010, 05:26 AM
  2. Difference Between Shift Times and Base Pressure
    By ssvolvo in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 19th, 2009, 01:36 PM
  3. T42 With Missing "Shift Times" Parameters
    By swingtan in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 26th, 2009, 10:14 AM
  4. Shift Times
    By BustedTruck in forum Gen III V8 Specific
    Last Post: January 1st, 2008, 12:53 PM
  5. Need help-Can't reduce shift times!
    By Mach2 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 2nd, 2007, 07:18 AM
