Results 1 to 9 of 9
Thread: lean cruise
    Dec 2005
    Default lean cruise
    has anyone used the lean cruise i was thinking about trying it not sure i understand the table is it like the pe modifier based on rpms like if you put 1.1it would be 14.68*1.1=16.14 air fuel commanded using a wide band to watch it of corse thanks
    Oct 2004
    Lean Cruise will only work if you have a Holden vehicle. There are already threads about that.. But there is specific code in the PCM that looks at the vehicle type and EFILive can not get around it.
    The closest you can get to it is by using a EFILive V3 custom OS and using the {B3647} Open Loop fuelling table.
    Not the answer you were after, but hope it helps.
    Andrew
    EFILive Crew
    Lifetime Member MN C5's Avatar
    Mar 2005
    PM sent...........
    Quote Originally Posted by Tordne
    There is a difference between 'can no't and 'will not'
    Oct 2004
    Quote Originally Posted by GMPX
    I know that mate, when you have the code you can do anything. I just didn't want to start the pleading . For legal reason it's won't be done etc.
    Andrew
    EFILive Crew
    That's the funny part, the bypass is happening out there from someone who should no better, nothing to do with EFILive thankfully.
    Lifetime Member mistermike's Avatar
    Dec 2003
    I tried the lean cruise on my Holden/GTO and it was kind of wierd. It was acting like it didn't want to disengage when my vehicle speed dropped below the trigger point. I'm not sure if this behavior is normal or not. I wound up using the AFR/RPM/kPa table in O/S 3 which can be applied to any car, and it works fine for that purpose.
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    Lifetime Member 87gmc's Avatar
    Apr 2004
    Can you say NOP
    Your cats wont like it thats all i have to say about that
    Oct 2005
    Also stock holden values are apparently too high, like 16.x:1 word has it that mid 15's are the best target for all round cruise.
    I use a combo of b3647 in OS3 and lighter lean cruise settings.
    2014 VF SV LS3 Maloo.
  1. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 12:44 PM
  2. RR Lean cruise?
    By BRD-PREY in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 11th, 2009, 05:31 PM
  3. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 08:42 PM
  4. Lean Cruise - US - LQ4 6.0L - Anyone done it?
    By Zfreak in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2007, 10:58 AM
  5. how to set lean cruise
    By bifster in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2006, 07:20 AM
