Results 1 to 3 of 3
Thread: ECM not detected.....HELP!
Hybrid View
    Apr 2005
    Default ECM not detected.....HELP!
    I was trying to get my tune out and it said "ecm not detected". Anyone know what could cause this? I'm suppose to get it back on a dyno in a couple days and swap out the intake for a fast 90 / 42lb inj. and need to tune a little. I doubled checked my connections and everything seemed good. The computer recognized and communicated with the flashscan cable.
    22:17:55.909: Scanning for EFILive FlashScan V1 USB
    22:17:55.924: Autodetect interface ...
    22:17:56.096: Interface firmware version: 1.2.17
    22:17:56.096: Connection to [FSP] interface is OK
    22:17:56.127: Interface firmware model: FSP
    22:17:56.143: Interface firmware version: 1.2.17
    22:17:56.158: Interface firmware date: Jan 18, 2005
    22:17:56.174: FlashScan serial number: 003481959964
    22:17:56.190: Disconnecting ...
    22:17:56.205: Disconnected
    22:17:56.860: Scanning for EFILive FlashScan V1 USB
    22:17:56.876: Autodetect interface ...
    22:17:57.048: Interface firmware version: 1.2.17
    22:17:57.048: Connection to [FSP] interface is OK
    22:17:57.048: Current protocol set to: "SAE J1850 VPW"
    22:17:57.063: Autodetect ECM...
    22:17:58.108: ECM not detected.
    22:17:58.124: Interface firmware model: FSP
    22:17:58.140: Interface firmware model: FSP
    22:17:58.155: Interface firmware version: 1.2.17
    22:17:58.171: Interface firmware date: Jan 18, 2005
    22:17:58.202: FlashScan serial number: 003481959964
    22:17:58.732: Getting status...
    22:17:59.606: Status: Calibration missing.
    22:18:03.243: Bootloader version: E38a_v1.2R (06D6-325C)
    22:18:03.243: Preparing ECM for reading flash...
    22:18:05.302: Autodetect interface ...
    22:18:05.334: Interface firmware version: 1.2.17
    22:18:05.349: Connection to [FSP] interface is OK
    22:18:05.349: Autodetect ECM...
    22:18:07.393: ECM not detected.
    22:18:08.422: ECM may not be secured - did not reply to seed request
    22:18:08.422: Initializing ECM...
    22:18:08.422: Initializing ECM, step 1 of 4
    22:18:08.438: Initializing ECM, step 2 of 4
    22:18:08.438: Initializing ECM, step 3 of 4
    22:18:08.454: Initializing ECM, step 4 of 4
    22:18:13.477: No response from ECM. Retry 1...
    \'99 SS Camaro #3789 6 speed ls1 12.6 @ 112.8 1.93 60\' .......now crate ls6 417 rwhp & 395 rwtq 10.9@129.8 \'03 2500HD ecsb 4x4 6.0, 4:10, locking diff, UPD, desreened maf 16.1@ 86
    Aug 2011
    What OS are you running on the computer?
    I found I have to run in admin mode in Vista and Windows 7 or I get that message sometimes.
    It looks like you are trying to read an E38 with a V1 cable. This is not possible, the V1 cannot communicate on the CAN bus the E38 uses.
  1. interface not detected on lmm
    By 2500HeavyDuty in forum FlashScan V2
    Last Post: March 5th, 2011, 04:41 PM
  2. No vehicle detected 06 duramax
    By rodder55 in forum FlashScan V2
    Last Post: October 27th, 2010, 07:32 AM
  3. Interface not detected problem
    By icetraxx in forum General
    Last Post: January 12th, 2010, 08:56 AM
  4. error interface not detected
    By drdarthinvader in forum FlashScan V2
    Last Post: December 7th, 2008, 06:11 PM
  5. What could cause timing to be pulled with no KR detected?
    By ArKay99 in forum Gen III V8 Specific
    Last Post: September 15th, 2008, 10:09 AM
