I seriously had a strong dream that I tried to read a Cruze AT as a T43 and it worked! I am going to try it for real. But what do you guys think? And I know it's tough but could you pleeease support the T76?
8.7 @ 84 (1/8 mile) bolt-ons
It won't work, each controller GM have uses a different seed/key algorithm for unlocking (which must be done to initiate the read process).
I don't think the T76 has ever been out of the question, the problem is getting one. They can't be found at a wrecking yard unless you want the transmission with it! Last time we checked they were on restricted order via GM parts outlets.
No, prob, thanks we'll just wait until they become more readily available
FYI, T76 TCM reading will be in the next V8 update due for release next week (but no programming or tune editing).
At this stage we just want reads from whatever vehicles have them to evaluate interest levels.
Like the T43 there is lots of different service numbers for these, so compiling a list of vehicles using them is a little tricky, at best I can say that the following transmissions use them, so far all small to med car FWD applications. The earliest reference I could find was a 2008 Captiva, but they may go back earlier than that, I don't know.
RPO Name Desc
MH9 6T30 FWD
MHC 6T40 X23FHD AWD
MH7 6T40 X23FHD FWD
MHH 6T40 eAssist
MH8 6T45 X23F FWD
MHK 6T50 FWD
MHJ 6T50 AWD
ty
