Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: Need some help with fuel trims.
    Aug 2011
    Default Need some help with fuel trims.
    I have a 2002 chevy 1500 with a 5.3 with a baby cam from comp actually the smallest one above stock. the motor otherwise is pretty stock. I cant seem to get lt fuel trims in check. no matter what i add the dont seem to change. Im very new to this some any dumb down answer will help I tried the autove tutorial i cant seem to get it to work even though i follow step by step cant seem to understan it. so i have a datalog file please take a look and tell me what you see thanks in advance.
    Hi goldenhp, can you also post your tune file.
    Senior Member johnmaster's Avatar
    May 2011
    Also make sure you are following the calc vet tutorial posted at the bottom of the original post of " A new twist.." thread on the stickies at the top of this forum. I tried following the outdated one in the software pdf tutorials and got all kinds of mixed up. Once I was working off the right tutorial it worked mucho better.
    A-New-Twist-on-CALC.-VE-Table..Computing-the-Entire-VE-Table.
    This is what John is referring to (see red box):
    Aug 2011
    its been a crazy weekend sorry for late response here is what i got now please let me know what you got for input. I will look through the tutorial again to see if i understand it.
    Aug 2011
    I dont have a wideband 02 hooked up to the v2 so could the cal vet still work.
    Lifetime Member Gregs's Avatar
    Sep 2008
    you can still use the ltftbens to get your part throttle map portion tuned. take a look at b3601 and update it if needed. looks like you still have all your tm in the tune..
    what part number is your comp cam/ or specs
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Aug 2011
    comp 54-408-11
    What is tm short for? prolly a simple question jus making sure.
    Sep 2008
    cool beans i have the same cam, i'm lovin it its got some great torque to it and i swear i'm getting better mileage
    Stock for now
    Aug 2011
    hey gregs, I was jus going over your sig and i believe its the same came you got. But without the intake ,exhuast or lift either. Do you have more done to your truck? If not we basically have the same setup.
    Did you have to tune it at all. if so what did you have to change?
  1. Tuning with fuel trims
    By 68problemchild in forum Gen IV V8 Specific
    Last Post: July 30th, 2011, 08:43 PM
  2. Why negative fuel trims after autoVE
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: July 16th, 2010, 11:14 PM
  3. E38 fuel trims
    By minytrker in forum Gen IV V8 Specific
    Last Post: July 2nd, 2010, 02:44 PM
  4. HELP fuel trims and AFR all over the place?
    By warscout2 in forum Gen III V8 Specific
    Last Post: January 30th, 2008, 11:31 PM
  5. Fuel Trims are 0
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 17th, 2007, 04:15 PM
