Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: TCM Flash - NOW TRUCK WON'T START - HELP
  1. #21
    May 2009
    You should maybe study the fuel system on your truck not possible for a flash to cause fuel drain back that would be like your software at work causing a hydraulic fitting to loosen up
  2. #22
    Sep 2010
    You can rule out the VATS speculation. In theft mode the truck will fire and die. The fuel delivery system is mechanical aside from the actual injectors. Even the pressure relief is mechanical. Elecronically it can only command the injectors not to open and your fuel pressure is normal when in theft mode.
    I see this all the time and have never thought much of it. One of my LBZs did this yesterday. Prime and go back to work.
  3. #23
    If you spent a bunch of time cranking over with a VATS (or other) dead issue, then perhaps that is what drained your lines. Just a thought.
    I have flashed thousands of LLY truck, and never had this happen.
    Custom Tuning Services
  4. #24
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Sounds like you need a lift pump bud. Losing prime is a mechanical problem, not electrical. You have an air leak somewhere in the system. It will happen again, but next time you might not be at home when it does it.
    Dan's Diesel Performance
    www.dansdieselperformance.com
  1. ECM swap and truck won't start
    By dansdieselp in forum Duramax LLY
    Last Post: February 4th, 2011, 08:07 AM
  2. MY TRUCK WON'T Start, HELP
    By ptownbacker5 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 6th, 2008, 08:43 PM
  3. TRUCK WON'T START AFTER DSP5 instal
    By vortecfcar in forum General (Diesel)
    Last Post: June 8th, 2007, 04:43 AM
  4. HELP! PLEASE HELP!! Truck won't start!
    By Wasted Income in forum Duramax LLY
    Last Post: January 6th, 2006, 03:00 AM
  5. Help Truck Wont Start - Flash messed up somehow?
    By BlownAlaskan in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 11:17 AM
