Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: TCM Flash - NOW TRUCK WON'T START - HELP
    Sep 2011
    Default TCM Flash - NOW TRUCK WON'T START - HELP
    I have a 2005 LLY /5spd Alli. This is my first use of EFILive. I uploaded the TCM successfully. I changd the max shift defuel to from 89% to 50%. I flashed the 5spd Ali TCM back into the truck. Now it won't start.
    The TCM flash said it was successfull. I don;t have any errors or tr0uble lights.
    Can someone please help me get my truck running again!
    Thanks.
    Jun 2011
    Flash the original tune file into the TCM and see if the problem goes away.
    Sep 2011
    I tried that right away. No luck.
    I also took the battery cables off for a few minutes, No Luck.
    I tried a Vats relink, no Luck.
    I set the Vats to disable in the PCM, No Luck.
    Jun 2011
    Does the engine crank/turn over?
    Did you change the Vin that's stored in the TCM?
    Did you check the stored vin against your trucks vin?
    To change the vin, open the scan tool, select the proper controller, then at the top of the page click on Bidirectional>Change Vin and enter the proper vin.
    Sep 2011
    Yes the engine cranks, it just won't fire.
    I just checked th vin and it matches the truck as well as the PCM.
    One wierd thing, Even though it was showing the correct vin, I tried to use scan tool to reset the vin as explained, but it failed with "Security Access Denied"?
    Sep 2011
    Thanks for the help so far!
    I can't think why the engine would not run after a TCM flash, can you read the ECM?
    Sep 2011
    Yep I backed up both before starting the whole process. I can read and write both without errors.
    I can't think of any scan tool pids to watch to see why it won't start. It's got to be something with the Vat.
    Sep 2011
    I'm trying the whole Vat relearn timer thing now. 15 min key on for 3 cycles. I can't think of anything else to try?
    Do you have any DTC's
    AL
  1. ECM swap and truck won't start
    By dansdieselp in forum Duramax LLY
    Last Post: February 4th, 2011, 09:07 AM
  2. MY TRUCK WON'T Start, HELP
    By ptownbacker5 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 6th, 2008, 09:43 PM
  3. TRUCK WON'T START AFTER DSP5 instal
    By vortecfcar in forum General (Diesel)
    Last Post: June 8th, 2007, 05:43 AM
  4. HELP! PLEASE HELP!! Truck won't start!
    By Wasted Income in forum Duramax LLY
    Last Post: January 6th, 2006, 04:00 AM
  5. Help Truck Wont Start - Flash messed up somehow?
    By BlownAlaskan in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 12:17 PM
