Results 1 to 10 of 12
Thread: EFILive can't communicate with ECU
    Sep 2011
    Default EFILive can't communicate with ECU
    I've just put an EFI 304 and 5spd out of a VN Commodore into my VK. It starts and runs fine, but can't get EFILive working with it, it shows this...
    Code:
    52:09.872: Initialising...
    52:10.339: Opening COM7 160,8,N,1
    52:10.536: Ready.
    52:20.797: Opening COM7 160,8,N,1
    52:25.243: Check vehicle interface...
    52:25.257: Interface not checked because 160-baud interface is selected
    52:25.271: Scanning for heartbeat and chatter frames...
    52:25.271: Waiting for Aldl bus silence of at least 50ms...
    52:26.421: Com timeout: Expecting frame header byte
    52:26.466: No chatter found
    52:36.672: Start macro: Get ALDL data: ALDL
    52:37.779: No data on 160 baud data bus
    52:37.779: Com timeout: Expecting start of frame symbol
    52:38.894: No data on 160 baud data bus
    52:38.894: Com timeout: Expecting start of frame symbol
    52:40.014: No data on 160 baud data bus
    52:40.014: Com timeout: Expecting start of frame symbol
    52:40.032: Stop macro: Get ALDL data: ALDL
    Anyone know wat could be going on?
    Cheers.
    Is the interface you are using plugged into COM7 which is what the software is attempting to use? COM7 is not likely to be a real COM port. It is more likely to be a virtual COM port.
    Make sure you have the 160 baud interface constructed correctly and make sure it is plugged into a real RS232 serial port (not a USB-Serial converter).
    Unfortunately most laptops no longer have real serial ports and the 160 baud protocol/interface will not work correctly with a USB-serial converter.
    Sep 2011
    I bought this off of ebay.
    http://www.ebay.com.au/itm/290599854...ht_3149wt_1139
    When I plugged it into my laptop and installed the drivers, it shows up as COM7 in device manager, and have set EFILive to use COM7 as well.
    Just checked all the USB ports and they show up as COM7, COM8, COM9 and COM10.
    I suggest contacting the seller for help on how to make it work correctly.
    Sep 2011
    I already have, this is the reply I got from him. Everything seems fine tho.
    Hi there,
    There are two things I would check.
    1: Check that the COM port is setup correctly. COM7 should be fine, but you need to check that it is the same value in the DEVICE MANAGER->PORTS section, and also configured in EFILive or WinALDL as COM7. Everything needs to be on the same COM port otherwise the software can't talk to the hardware. Also, if you plug the cable into the same USB port on your computer, it usually gets the same COM port number. If you plug into a different USB port, sometimes you get a different COM port number, so its best to check.
    2: The ignition needs to be in the ON position for the car computer to start talking to your laptop. If the ignition is in the OFF position or the ACC position then no data will transfer and you will see errors like the log you pasted shows. The car doesnt need to be running, but the key needs to be in the ON position. You can tell that the car computer is trying to send data because the CHECK ENGINE light will flash in a strange way (bright and dim). If you have a VN computer in a VK commodore then you may not have a CHECK ENGINE light to look at.
    I hope this information helps.
    Have fun!
    Regards,
    John.
    Have you tried WinALDL? Does that report no data as well?
    Sep 2011
    I haven't tried that, I better give it a shot. I guess that will tell me if it's the program or the car (or my computer lol).
    Just changed the COM port from COM7 to COM2 just incase it doesn't like COM7 or sumfin. Will go have another crack in a sec.
    Could it be because of my wiring? I wired up the EFI 304 myself, and I haven't wired up alot of the gear which I don't need, like the thermo switch wire, air con wire, gearbox wires. I just assume if the ECU is running the car fine it should be all good....but thought I should ask.
    I can't help with the wiring. Do you have any access to a VN Commodore that you could connect up to to verify that the interface and the software are working correctly?
    Sep 2011
    Just tried it again and still nothing, on EFILive or WinALDL.
    One of me neighbours mate's has a VN V6 and he's there regularly....will go hit him up when I see him pull up next.
    Till then, I rekon I'll wire up the engine light just incase the circuit needs to be completed on that for it to send out signals through the ALDL connector.
    Sep 2011
    I hooked a test light up to the engine light wire (so the test light becomes the temporary engine light) and it started working! Beauty!
    Thx for the help aye!
  1. Efilive Cannot Communicate With Flashscan Error???
    By nitrorocket in forum FlashScan V2
    Last Post: July 28th, 2008, 11:14 AM
  2. EFILive cannot communicate with Flashscan
    By Blackbird345 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 12th, 2007, 11:20 AM
  3. Cannot Communicate with Flashscan
    Last Post: May 24th, 2007, 02:05 PM
  4. Cannot Communicate with Flashscan
    Last Post: May 16th, 2006, 01:48 PM
  5. Can't communicate with FlashScan
    By mcwarren in forum General (Petrol, Gas, Ethanol)
    Last Post: March 18th, 2006, 12:38 PM
