Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: UK Project BMW E46 357ci V8
    Default UK Project BMW E46 357ci V8
    I thought I'd share my little project that's been keeping me busy for the last few months...
    I do some wiring work for Craig Taylor @ DynoTorque apart from running a motorcycle dyno Craig is also an expert fabricator/engineer & puts LS 1/2/3 engines into different cars, I do the wirirng on them for him & the V8 rumble/torque has finally got under my skin so he's making me one
    I bought a 2001 325 M Sport Coupe for the conversion into which is going an LS1 5.7l GTO engine & 6 speed box, it's not 'just' an engine swap tho it'll need hand made header pipes, prop, steering rod etc & while we are it were installing the rear end from an E46 M3 to give the car an LSD, upgrading the suspension & brakes as well as sorting all the niggles with the car.
    The Car...
    M3 LSD Diff & rear end
    LS1 5.7l GTO Engine & box
    Laser cut widgets for the custom headers
    The Carbon cube trim was worn out on the drivers door & needed replacing as I had to the door trim off to fix the CDL I decided I'd have a go at painting the trim & see what it looked like
    Rear AP calipers being sized up for brackets onto M3 read discs
    I sourced an M3 propshaft from a local breakers for £95
    Put my old black MV1's on still not sure on what to do about wheels unlike most I really like MV1's but this is 3rd car that's had them,,,,
    Well the scales say 1421KG lets see how much it gains when it's finished.
    Craig measuring up for the mounting brackets for the AP Calipers & bigger discs
    Brakes
    It needed a small spacer to clear the wheel but I'd intended to run spacers as the wheels sit to far in anyway so I popped next door & pinched some from driftworks....
    Next up is the AP rear calipers
    While I was @ driftworks I got Phil's old H&R anti roll bar off him for mine, my pile of stuff in the corner is getting bigger
    Ready for bodyshop
    Rear brakes are done
    Car is back from bodyshop & Driftworks brought round a load of boxes (HSD's anti rollbars brakelines & loads of powerflex bushes.
    The new radiator, engine mounts & fuel pressure reg/filter have been delivered too.
    Shiny things
    Complete back end removed so Craig can stiffen up the subframe mounting points
    Good job we were planning to stiffen the back end up.... the trained eyes will see the crack starting & the movement on the spot welds
    Removed the 2.5 engine/gearbox/wiring & front suspension.
    There isn't a lot of the car I bought left...... More shiny stuff arrived today too
    The DynoTorque subframe kit waiting to be fitted
    Craig has had a look at the engine & the clutch is fubar'd It seems clutches are a weak point on LS1's & the clutch of choice is an LS7 but to fit an LS7 clutch you need an LS7 flywheel too all in about £700 ish :( Why did I buy that cam LOL after a bit of surching I found a brand new one that's been taken off a new engine for £300
    Ive put the new front shocks on
    Craig busy making a racket grinding & then welding in the DynoTorque subframe strengthening kit
    Painted the repair
    Subframe poly bushed
    & then got it back into the car
    Got the rear suspension & brakes on & ran new braided brake lines to the front
    I'm so sad!!!!
    Craig's made an new steering arm & relocted the ABS
    When I ordered the engine I ordered it with a certain type of sump unforttunately the breaker didn't have one so he fitted a different one thinking it would be ok so after a quick measure up it defo won't fit with this sump & I've been able to source one in the UK so the sump he's fitted is being sent back & a the correct sump is being sent out to me, so just a case of being patient which is something I fail at!!!! The frustraiting thing is had he asked we'd have told him the sump he fitted wouldn't work.... until the sump is in Craig can't mount the engine, so he can't make the headers or get the propshaft modded & I can't start the wiring etc....
    I've made a start on the wiring....
    & pushed it outside for a wash
    The black wheels look better clean & in the sunlight
    Done most of the engine loom
    As I said not much can be done until the sump etc turn up but I've been doing my best to keep it moving along...
    All the brake lines are now connected to the moved ABS pump
    Done as much of the wiring as I can for now
    What do you do when you can't buy a big enough back box? Well if your Craig Taylor you just cut/weld/bend one till it's the right size....
    And then this morning Fedex handed me a package....
    Just waiting (still) on the sump despite lots of assurances from the place I bought my engine (Calspeed & Performance) from were still waiting for them to sort their mistake out.
    A minor update
    Sump has finally tuned up late today so things should start moving forward, not that we've been idle while waiting for it..
    Craig has fitted the new cam, cam chain, pushrods, uprated valve springs & collets
    The engine just waiting for the correct sump.....
    We've been able to do a bit on the exhaust & some of the pipework under the bonnet
    A friend of mine has been over today looking at the canbus side of things & it's quite involved & going to take some work to do so as temp quick fix I'm going to install a set of E36 clocks I have while Rob works on the can bus.
    This morning Craig fitted the LS7 clutch & T56 gearbox together & then poked the engine into the hole.....
    & the he made some engine & gearbox mounts
    & it's in
    That's a very long difficult day made to sound very easy.... it's not trust me!
    I've dropped the prop off to be shortened & have the correct end fitted for the T56 box & in the morning I'm off to Jetex to collect the bends & pipe/parts so Craig can start making the headers
  1. bought someone elses project and am trying to get it right.
    By redfury in forum Vortec V6/V8 Specific
    Last Post: February 16th, 2011, 02:38 PM
  2. 2010 Camaro Supercharger Project
    By mirage in forum Gen IV V8 Specific
    Last Post: July 10th, 2010, 03:26 PM
  3. Project LS1 Airboat is go !
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2008, 06:53 AM
  4. My next project
    By Till in forum General (Petrol, Gas, Ethanol)
    Last Post: May 30th, 2005, 07:44 AM
