Results 1 to 8 of 8
Thread: what ECU is in 08\2011 E85 ssv L77 engine
    Dec 2009
    Default what ECU is in 08\2011 E85 ssv L77 engine
    Hi guys I have a 8\2011 with L77 engine in to tune can you tell me what ecu it is?I can read it with E38 but I get a bad format code.Is there software to do this later model?
    Should be just a normal E38.
    We cover up to the very latest model so support should not be an issue. When was the last time you updated your software?
    http://www.efilive.com/index.php?opt...=48&Itemid=133
    Dec 2009
    Default update
    I updated this morning before conecting to vehicle.
    Did you update the V2 firmware as well?
    Dec 2009
    No I didn't I'll give that a go.
    Dec 2009
    I ran updates for both 7.5 and V8 now get error $0025:cant get semaphore for control of EFIlive_Hapi.ok got over that now getting flashscan status unresponcive in V8 firmware window yet it works in tune and scan programs.
    Reinstall V8 software.
    Dec 2009
    thanks for that I had already done that which fixed the semafore code.my other problem was fixed when i updated the firmware.all good now thanks.
  1. need moer power L77-76
    By holden77 in forum Gen IV V8 Specific
    Last Post: August 2nd, 2011, 08:18 PM
  2. L77 wanting more power
    By holden77 in forum Lounge
    Last Post: July 26th, 2011, 11:44 PM
  3. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
  4. P2a04 coming up one VE SSV
    By DMAX403 in forum E37, E38 & E67 PFI ECM's
    Last Post: January 11th, 2011, 05:16 PM
  5. Holden VE SSV Missing Calibration 12619077??
    By JezzaB in forum E37, E38 & E67 PFI ECM's
    Last Post: December 18th, 2007, 04:27 PM
