I have been having problems with tunes lately since the new option of setting the limiting of duration . What has happend is when using say OS 11501001 , which is for an 07 manual, everything else in tuning works but when you set the duration limiter to minimum it makes no change. I tried other 06 OS's for manual and ran into the same problem. I reused the stock tune from my truck which still has the high idle enabled (os 11352602), and well it worked till yesterday i just reconfigured my pedal postion tables and saved, loaded as normal with no hitches. Get out and hammer it in when it hits 3400rpm, bam it dropped off.... Now this same tune has worked the past few days till I adjusted the pedal position. Shouldnt have any bearing on the duration limiter. Filters are new, good fuel, so on and so forth.
I talked with FUBAR , and hes been having the same issues. I have tried reinstalling 7.5 and 8.2 softwares, making sure all firmware is the latest, umm just about everything i can think of . Tried making a script of the current tune and running over clean copy of my stock tune and still the same results . Really frustrating.
This with andrews issues being the same , Im suprised some big tuners havent seen this yet. May not happen with all OS's im not sure.
Ill attach a log to .
