Results 1 to 7 of 7
Thread: Brake Torque WOT help
    May 2009
    Default Brake Torque WOT help
    Ok...here's the situation. 08 E67 Trailblazer 5.3L (12618163). I brake and rev her up to about 1500 rpm at which point she starts to tug at and push through the brakes. I release the gas and she rolls out then kicks into high power around 2000 rpms. I know there is more power to be had at launch...but I can unleash it. So I logged it. Clearly the electronic throttle body is staying shut as seen in the log. BTM is set to YES. Now I've have tip in throttle and all torque management off or set high. B5208--> is zero'd except for 1000= 50. Traction control/Stabilitrak is OFF. But I can't for the life of me figure out what parameters I'm over looking that won't let that her launch with all she's got.
    Any suggestions on where to focus my attention regarding the issue of the throttle's slow to open with brake torquing? I've attached the log...just jump up to frame 2260 and you'll see the note markers.
    Log-->SWEEET.efi
    Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
    Dec 2007
    Quote Originally Posted by TBMSport View Post
    Log-->SWEEET.efi
    Post the tune. Maybe can fix it for you.
    Aug 2010
    +1 on gmh308's comments.
    When you have a chance post both the ECM and TCM tunes - problem could stem from one or both.
    Regards,
    Taz
    Dec 2007
    Meep meep...
    May 2009
    Sorry guy...thanks but I figured it out. My sparks and fuel were on major retard. Logging is your friend!!
    Dec 2007
    And the reason they were out?
    May 2009
    mixing and matching model years calibrations and actual vehicles
  1. Brake Torque Management Screen Shots Needed
    By LeftCoast32 in forum Gen IV V8 Specific
    Last Post: September 5th, 2011, 03:11 AM
  2. B0401/0402 Brake Torque Management (BTM)
    By TurboCamaro in forum Gen III V8 Specific
    Last Post: September 30th, 2010, 08:55 AM
  3. Brake Torque Mgmt
    By jpowel29 in forum Allison 5 & 6 Speed
    Last Post: June 19th, 2009, 10:30 PM
  4. brake torque limit
    By 69camaro5speed in forum E37, E38 & E67 PFI ECM's
    Last Post: March 11th, 2008, 03:30 PM
  5. Brake Torque Management?
    By trudynosports in forum Gen IV V8 Specific
    Last Post: February 28th, 2007, 10:14 AM
