Results 1 to 4 of 4
Thread: Kill low oil level warning
    Senior Member johnmaster's Avatar
    May 2011
    Default Kill low oil level warning
    99 silverado 1500, I am not using the low oil level sensor anymore and wondering how to disable it in the tune so it doesnt display on the dash. Can't find the p code, wondering if there is one I can set to not show? Or do I need to fool the pigtail with a jumper/resistor?
    May 2011
    Found on ls1tech that it's just a switch (though I see no contacts anywhere, just a plastic drum floating on a shaft...?). Supposedly a jumper wire is all that is needed so I will test the switch and make a jumper and see how we do.
    Dec 2005
    Hello John,
    I am wanting to do the same thing. Please keep me posted on your outcome.
    Thanks,
    Glenn
    May 2011
    I still can't tell how it works but it is just a switch. The circuit opens when oil level falls, closes when oil level raises above the sensor. I cut the sensor up and popped the connector out of it, soldered the connections together, taped it up and attached it to the end on the vehicle and now it is satisfied, no oil level warning. Alternately you could just put a jumper wire on or cut the pigtail from the vehicle and splice the wires together.
  1. Low Oil light
    By 1bar in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2009, 09:32 AM
  2. low oil level
    By 69camaro5speed in forum Gen III V8 Specific
    Last Post: July 12th, 2007, 09:00 AM
  3. B1501 Low Oil Pressure Warning
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: April 26th, 2006, 09:42 AM
