Page 16 of 16 FirstFirst ... 6141516
Results 151 to 156 of 156
Thread: How about a transmission tuning tutorial!
  1. #151
    Member TLKSCHP's Avatar
    Dec 2005
    Maybe I missed it but If VE tables being off can drop line pressure what about when you spray a dual nozzle methanol set up which changes VE? Does this require doing something different? I'm back to fighting a WOT 2-3 shift issue. Bounces the limiter around 8 times then shifts firm. Also could be trans going again.
  2. #152
    Measure line pressure at the tap on the side of the case, see what it does during the shift.
    Also log GM.TFMPRS, GM.GEAR and the other pids (VSS, RPM, ETC or ETCTP, MAP, MAF, ECT, TFT, TCCMODE) and post here.
  3. #153
    Dec 2005
    Had to get new laptop, lost all my files and some reason couldn't get efi live to work but all good now I think.
    Just need to locate a pressure gauge.
    If i had to guess its not commanding the shift all the time. went to the track and 1 pass shifted okay 10.89 @ 128 but 2nd pass wouldn't shift into 3rd and pulled 2nd all the way to redline 100 mph at the 1000ft and just bounced rev limiter. I lift and put in D and it shifts.
  4. #154
    Quote Originally Posted by TLKSCHP View Post
    Post your tune file and some logs showing this.
  5. #155
    Dec 2005
    Well I planned on having a log to post today but i guess i still haven't figured out my software issue. Thought i got all the scanner 7.5 lined out and ready but all the pids, charts and themes are gone again. If i flash with V8 my dash wont work but is fine with 7.5 I noticed . starting to think i need to do a complete reflash i if can get this software working
  6. #156
    No worries, take your time.
    Use V7.5 to flash and log for this (for now).
  1. New Tuning Tutorial: WeathermanShawn
    By WeathermanShawn in forum Tutorials
    Last Post: March 1st, 2011, 08:31 AM
  2. Question on Tuning with AutoVE tutorial
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 1st, 2009, 02:35 AM
  3. How about a transmission tuning tutorial!
    Last Post: August 5th, 2006, 03:09 AM
  4. Simple yes or no...would you like a tuning tutorial for EFI Live?
    Last Post: July 22nd, 2006, 01:38 AM
  5. Tutorial for tuning VE using LTFT's using EFILive ??
    By Thedude in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2005, 09:55 AM
