Results 1 to 10 of 13
Thread: how to correct error code $0520
    Aug 2011
    Default how to correct error code $0520
    vehicle : 2011 chevy 2500 truck, 6.0l 6spd auto.
    trying to load autocal for datalogging , and keep getting error code $0520. tells me to wait 15secs, then retry. Black Bear performance has stated that it is an E78 engine controller. any insight on correcting the error code to load autocal for datalogging.
    Which versions of V7/V8 software and V2 firmware...?
    Did you correctly configure the BBx pidlists (including copying the configuration files for the ECM you're logging)...?
    Aug 2011
    Downloaded all the latest, (twice), double checked the configuration of the BBx using right ECM files, tried Data Log again and got error $0185. Went to Forum where someone had posted to uncheck a box, searched everything I could find without finding any boxes I could uncheck. Tried several more times always getting the $0185. Whats next?
    Quote Originally Posted by warlock06 View Post
    Did you install these:
    http://download.efilive.com/Software....180_Setup.exe
    http://download.efilive.com/Software....170_Setup.exe
    Did you update your V2 firmware to 2.07.22...?
    In V8 S&T, goto the BBx tab, and on the Scan and Tune subtabs delete all the pidlist/ECM entries that are not for your ECM, and Save.
    Then format the config space and re-program the pidlists:
    - click the down arrow on the Program button and select Format Config File System,
    - click the down arrow on the Program button and select Program All Required Data (Slower),
    Aug 2011
    Severial attemps made, still recieving error $0185. Any hands on help in the St. Louis, Mo area.
    Did you install those without doing Check for Updates...?
    Post some screenshots...
    Aug 2011
    Yes, updated everything before installing and the screen said that everything was good to go. The firmware would only update to 2.07.17 but the screen said it it was good.
    Jul 2004
    If the firmware is 2.07.17, you need to get the most current version of EFILive as you don't have it.
    Go to www.efilive.com
    then to Download => Download Software
    The download the V7.5 and V8 from there
    Install them both
    Do not at this time run the update utility.
    Now run V8 and it should offer to update to boot 2.07.03 and firmware 2.07.22.
    If it does that, you have the most current version
    Ira
    Aug 2011
    Did all that, got the right versions, go out plug it in and get error $0182!!
    Jul 2004
    There is a document you should be aware of:
    Start => All Programs => EFILive => V7.5 => Documents => EFILive Error Messages
    That error means you need to format the config file system. Open up V8, Click the BBX button, then click the little arrow at the right edge of the Program button and choose Format Config File System.
    Ira
  1. error code $050B
    By hawaiianstyle in forum AutoCal
    Last Post: January 28th, 2011, 10:53 AM
  2. Error code
    By Toired Old Man in forum FlashScan V2
    Last Post: October 24th, 2008, 09:17 AM
  3. error code 11?
    By dynarex in forum General (Diesel)
    Last Post: April 23rd, 2007, 10:07 AM
  4. Error code: ERR_NOCABLE/31
    By Chalky in forum General
    Last Post: May 16th, 2006, 09:40 AM
